Racetech spring weight
Old Mar 12, 2018 | 11:38 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by Puglia10
Do you have any recommendations for me at 185lb, pretty aggressive riding...I already bought 1.0kg Racetech springs and Ricor Intiminators. That setup should be OK right? Suggestions on setup?
Didn't know my 08 forks were different than others? Just bought it.
I've not used the Ricor stuff.. The valving design is different than the Racetech stuff. I would try what you have but use 5 wt oil.. It's just a guess om my part. You might want to call Ricor and see what they say.. Hopefully they have to data. The stock bagger spring is still less than 0.7 kg/mm which IMO is way too light.
The 06 to 08 fairing bikes have different springs / damping rods and emulator valve than the 09 to 13 bikes. I suspect that HD opened up the rebound oil on the damping rod on the later bikes and don't know what the changes are to the springs and emulator valve..
Old Mar 12, 2018 | 01:48 PM
Puglia10's Avatar
Puglia10
OK thanks, Ill give Ricor a call. Seller just told me the Ricor valves I bought from him were already modded by Fabrik8ter so that's a plus!
Old Mar 12, 2018 | 04:01 PM
Max Headflow
Fabrik8ter might be the guy to talk to if you can get a hold of him.. As I understand it, he spent a bunch of time tuning the valve. He probably has an springs that works well.
I found this discussion where he says he used 1.0 kg/mm
https://www.hdforums.com/forum/touri...ml#post9273578
Don't know what bike he used tho..
Old Mar 12, 2018 | 04:22 PM
grbrown's Avatar
grbrown
'fabrik8r' is Jason Ward, who transmogrified into 'Wardspartswerks' when he designed and introduced a pair of cylinder cooling fans for big twins. Unfortunately he hasn't been around for a while now, last posted in 2016, so getting in touch may be a problem.
Old Oct 13, 2020 | 01:16 PM
mshred's Avatar
mshred
Since the 08 and 07 have the same damping rods an valving on faring bike. This is what I did to my EGC..
Use progressive standard weight springs, 5 wt oil (Spectro or Maxima) and drill the center of the HD emulator valve out to 7/64ths..
Preload to 25/30mm.. I weight 190 and 25 works a little better. Add a little bit if you are heavier. This is a good setup on rough roads with potholes but still rides pretty well. Bike gets ridden aggressively. If you want want a softer ride you can use emulators but only do 1 or 2 holes in the hat/valve and gold springs set to 2 to 2 1/2 turns.. Warning, the RT valve will bottom severely on bad pot holes. I removed the RT emulators and went back to then HD version.
As stated, passenger and bags are in the back.
i know now I am doing some serious thread resurrecting here, but I was about to pull the trigger on some racetech gold emulators and 1.0 springs for the front of my 08’ eg classic. I weigh 205lbs. Figured I’d do some research before pulling the trigger. Glad I did
what is different about 08 bikes? Racetechs site says I need 1.24 springs but they don’t even stock them
Old Oct 13, 2020 | 02:06 PM
Puglia10's Avatar
Puglia10
Cant help you with whats different for 08, but for my 08 RG I ended up doing the 1.0 racetech springs and ricor valves and was very pleased. 185lbs.
Old Oct 13, 2020 | 02:11 PM
mshred's Avatar
mshred
Thanks for the response! I figure the 1.0 springs would be quite a step up from stock, and with their gold emulators (it's a kit) that it would make a noticeable difference. But this thread had me wondering if 08 was somehow different in any way.
Max Headflow
Not sure what the question is about the 08 bikes. From 06 to 08, the fairing bikes already have emulators (Showas version). 09 to 13 had slightly different valves, springs and emulators.
The Spring rate calc on RT website is currently screwed up on the spring rates. They give you the same spring for 4 inch travel fork (TC bagger, 14 and up) as they do for a 5 inch fork, (13 and earlier TC bagger). Think about it. With a 4 inch travel fork, compressing the fork 4 inches with a 1.25 kg/mm spring will yield the same spring pressure increase as compressing a 1.0kg/mm 5 inches.
I'd rebuild your forks with stock HD emulator, 5wt oil, and the 1.0 KG/mm springs. Drill the center hole out in the HD emulator to 7/64. Stock springs are about 0.7 to 1.6 kg/mm (last 1 1/2 inches). They suck.
Old Oct 13, 2020 | 02:15 PM
mshred's Avatar
mshred
You just answered my question, thank you. I had seen in a couple other threads that 08 was different, but I wasnt following with what.
Clearly you know a lot more about suspensions then I ever will lol.
The mod to stock HD emulator along with a 1.0 spring will make a noticeable difference? Enough to not warrant the race tech golds?
New springs are definitely in order up front, going to address the rear shocks as well. Staying standard ride height, but want something that works without going super fancy (ballin on a budget)
EDIT- just realized you are who I quoted. Our roads are GARBAGE HERE...so I will maybe stay away from the rg emulators if bottoming out is an issue.
thank you!
Old Oct 13, 2020 | 04:53 PM
Max Headflow
thank you!
When I bought my EGC used, it had progressive heavy springs in it. Bought it used at about 10K so didn't have much of a chance to experience stock. They were way too stiff. I did get to put a few miles on a buddies ultra that had the front end lowered 1 inch. It was way too soft and would bottom hitting a driveway.
First thing I did was go to progressive standard. 10wt oil. Worked better,
Tried 5 wt oil worked better.
Went to RT 4 holes in the hat, gold spring 2 turns, 20w oil. This was supposed to be the trick setup Over rough surfaces the forks would pack. You could feel the front drop. The problem is that rebound on damping was too stiff compression too light.
Backed off to 2 holes, gold spring 2 1/2 turns, bach to 5 wt. This worked OK but pot holes would seriously bottom the forks.
So I went back to stock emulators and drilled out the center hole in the HD emulator, 5 wt and still the progressive springs.
Was replacing the lowers so I swapped over to 1.0kg/mm springs. For me this is a bit better but front end dive is a little bit more.
This was all done over a period of 90000 miles. Bike just turned over 100K
If you think the springs would be too light for you, you can go with progressive springs which are about 1.07/1.40kg/mm rate springs. or find some 1.1s.
I've also done Softail and RK forks.. IMO the RT emulators work great in the Softail and RK forks.
The issue seems to be the rebound damping holes are different but I really haven't spent any time comparing the different forks. I simply modified each to suit. Some took a couple tires.. EGC took more..
crusader1xxx
Jan 30, 2018 10:08 AM
Jskinner6483
2014-2024 Touring Models
Jan 8, 2017 07:38 PM
titleist07
Sep 15, 2015 06:18 PM
parts eeter
Nov 21, 2011 01:18 AM
Hitechluddite
Sep 1, 2009 09:09 PM
