electrical
Old Mar 22, 2018 | 03:07 PM
CanadianHD's Avatar
CanadianHD
Arrow electrical
hi guys. on a 2010 roadking behind the forks under the headlight, there is a plug. The housing to this plus appears to be broken so when you plug the male part in, it doesn't make a good connection and when you touch it, all the lights go off. It's like it triggers a relay. There appears to be a loop wire at the end, a jumper for some reason. I dunno what that's for.
Also the extra driving lights, I can't get them to come on at all. Are they on a separate circuit?
There is a toggle switch on the back of the headlight, doesn't seem to do anything but I suspect this is there because it was a cop bike.
Anyone have this problem? How do you fix it?
this is up behind the headlight
Old Mar 22, 2018 | 03:21 PM
dawg's Avatar
dawg
Toggle switch is for accessories if you use them. It would run anything you wire to the accessory plug/circuit. To fix that plug, get a new plug receptacle from dealer
Old Mar 22, 2018 | 03:27 PM
CanadianHD's Avatar
CanadianHD
Dawg;
do you think it's because of this plug that the lights kick on and off?
- is this a matter of cutting that plug out and soldering on a new plug? or do I need a whole new wiring harness.
-- ok I found that they wired the driving lights into one of the "red cop switches" thats why they would not go on.
Old Mar 22, 2018 | 04:43 PM
ORradtech's Avatar
ORradtech
At the risk of feeling like I write this in way too many posts here goes.
Buy yourself a factory service manual. It will be invaluable.
As for the plug, no soldering required. All HD plugs disassemble, instructions in the FSM. Any tools for r & r of the plug can be found easily enough on Amazon or eBay for not much.
Old Mar 22, 2018 | 05:09 PM
CanadianHD's Avatar
CanadianHD
ORradtech, I think I recall now that you mention that. These are the plugs that you push the pin above the wire to release them right?
Old Mar 22, 2018 | 05:34 PM
ORradtech's Avatar
ORradtech
Yes, kind of. There are several different styles of plugs on your bike. Each style is a bit different. Again, the fsm will tell all.
Old Mar 22, 2018 | 08:45 PM
14GuineaPig's Avatar
14GuineaPig
Go to this web site & enter your VIN. You'll be able to view the Owners Manual, & wiring diagrams for your bike.
https://serviceinfo.harley-davidson....cle/lookupForm
taf0104
Electrical/Lighting/Alarm
16
Jul 24, 2019 03:29 PM
cajun1957a
Oct 18, 2015 05:31 PM
cubalz
Nov 27, 2013 11:00 AM
misfitJason
Feb 6, 2013 01:01 PM
schumacher
Nov 6, 2009 07:37 AM
