power vision wire to controller..
Old Mar 22, 2018 | 05:33 PM
memphisharley's Avatar
memphisharley
Default power vision wire to controller..
is the wire long enough to reach from the connection location to the holder mounted on 10" mini apes? if so, how did you run the wire.
thanks
Old Mar 22, 2018 | 05:35 PM
Bowhunter61's Avatar
Bowhunter61
Yes, I had mine mounted on 10" Wild Ones, I ran the wire under the tank, under the ignition nacelle and then up the bars.
Old Mar 22, 2018 | 07:04 PM
memphisharley
thanks...i'll try that route.
edit: did you run the wire in the backbone or no.
Old Mar 22, 2018 | 09:59 PM
IKnowNot's Avatar
IKnowNot
Ran mine under the tank console.
That also keeps the wire away from the spark plugs that could cause interference.
Just leave enough wire coming out of the front of the console for the bars to turn.
No problem with length on my WO 578 10 inch bars.
Old Mar 23, 2018 | 07:34 AM
Bowhunter61
Yes, pulled the tank all the way off and ran it with the other wires up to the front. Mainly to keep it away from the plug wires as IKnowNot stated.
medicmouse
Electrical/Lighting/Alarm
Aug 2, 2017 09:46 AM
merlin125
Aug 7, 2013 10:28 AM
artizinn
Sep 9, 2011 03:58 PM
smokinfromshootin
Nov 20, 2010 09:01 PM
drogers
Jun 1, 2008 06:26 AM
