mp3 wiring
Old Oct 18, 2005 | 12:31 AM
scott's Avatar
scott
Default mp3 wiring
Hi all
looking for advise on where to install the wires for the harley mp3 player should i go to the battery and install a fuse link or is there some other place . the directions dont show where to hook it up
thanks scott
Old Oct 18, 2005 | 12:26 PM
Triple Z's Avatar
Triple Z
Default RE: mp3 wiring
ORIGINAL: scott
Hi all
thanks scott
Actually, the instructions do show the hook-up quite clearly. If you don't have the instruction sheet, I could scan a copy, and send it to your e-mail.
There are only 2 wires in the MP3 power harness. One fused wire (12V+) splices to a capped-off and unused wire that is bundled with the headlight harness.
The other wire is a ground, and must be connected to a solid grounding point like the chassis.
Old Oct 18, 2005 | 01:40 PM
scott's Avatar
scott
I must be missing that one doug if you can send it that would be great i only have the one that shows the 9 volt battery hook up
thanks
scott
scottco@yahoo.com
Old Oct 18, 2005 | 03:13 PM
pointswhat's Avatar
pointswhat
check out this thread. It talks about a switch on the back of the player. If the switch is in the wrong position the volume will be very low.
Old Oct 18, 2005 | 06:48 PM
scott's Avatar
scott
thanks point already did that got off ebay it said new but it must be missing wiring directions waiting for one of the guys to send me a scan of them
scott
Old Oct 18, 2005 | 07:41 PM
scott's Avatar
scott
Hey doug all set found the wires you were talking about thanks for the help
scott
Old Oct 18, 2005 | 10:57 PM
Triple Z's Avatar
Triple Z
ORIGINAL: scott
scott
Good!
But check your e-mail...I sent you a .pdf file of the installation instructions and the spare parts list. It may come in handy later on.
bulkness
2014-2024 Touring Models
Mar 31, 2014 12:40 AM
cdestuck
Mar 26, 2013 08:54 PM
AlaskaAviator
Mar 24, 2010 10:58 AM
ronyd
26
Dec 22, 2007 05:22 PM
Fxdxsp2003
Dec 18, 2005 01:12 AM
