Ohlin 2-2a shock and belt deflection setting
Old Mar 30, 2018 | 06:50 AM
Redrodyankneck's Avatar
Redrodyankneck
Default Ohlin 2-2a shock and belt deflection setting
This is a 12" shock with the 3.125 suspension travel. Are you guys using the standard shock or the low profile dimension on table 32 pg 153 owners manual?
Old Mar 30, 2018 | 08:35 PM
SnoRider's Avatar
SnoRider
Interested
Old Mar 30, 2018 | 09:48 PM
hbsoldier3's Avatar
hbsoldier3
Oops, did not see your sig, when I first posted. When I put my Ohlins on I did not even check the belt.
Old Mar 30, 2018 | 10:37 PM
sixguns's Avatar
sixguns
Your Street Glide came with 12" shocks stock, they are the low versions. you put 12" Ohlins on so your belt adjustment scale stays the same, use the Low scale, My Road Glide also came with 12" from the factory, I put 13" Ohlins on it so I use the standard shock belt adjustment.
File Type: pdf
Porgey
2014-2024 Touring Models
Mar 5, 2017 04:56 PM
Litewings
Jul 26, 2015 08:26 PM
Voelser
Jul 18, 2012 04:00 PM
Garcia85
Oct 10, 2010 01:50 PM
mogle
Oct 29, 2008 06:14 PM
