Brake lever help
Old Mar 30, 2018 | 11:10 PM
clap's Avatar
clap
I thought about that nuts. I contacted softbrake and no answer. All I see on the site is for 09 and up I need for an 06
Old Mar 30, 2018 | 11:33 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Originally Posted by nutsandbolts5212
Maybe you could branch off the rear master cylinder, running your front brake lines, and use the rear brake like a car. Just an idea!
This might actually be something to look into. Might do what Honda did with their Goldwing. Rear brake pedal also engages 1 front rotor only of the dual rotor setup. Yes, might be something to look at. See how Honda did it. Copy them.
EDIT~ Is this a safety issue? How is your arm/grip for steering in slow speed maneuvers? How about throttle sensitivity? The right hand does more than squeeze the brake lever. Engine cut off switch is another concern. Turn sig also.
WB
May 10, 2014 10:21 PM
2013superglideseattle
Feb 22, 2014 09:40 PM
billewo
Wheels/Tires
Jul 31, 2012 10:55 PM
strongwood
May 28, 2012 02:54 PM
banginTwins
Sportster Parts
May 31, 2011 07:08 PM
