FNG here
I have an '04 Electra Glide and at 72,000 miles I decided to upgrade to the Screaming Eagle kit. After pulling the original cam chain tensioners out, there was about .030" wear on them. According to the service manual, they should be changed after .090". So, mine were practically new and after all those miles.
Good luck with your bike.
I would be prepared (fix decided on & money ready) to get them changed when inspected, to save the time/trouble of finding them in need of replacement and not being ready to fix'em.
You have 4 choices:
1) Replace the spring tensioner shoes with OEM or Cyco shoes. This is the cheapest fix, and the Cyco shoes are much better than the OEM. Should last at least as long as the 36K you have now. Still need to occasionally check wear.
2) Upgrade with the HD SE hydraulic cam plate conversion. Not a bad choice, but while it upgrades to the hydraulic cam plate and tensioners, it uses the OEM linked cam chain on the back of the of the cam plate and the better o-ring cam chain on the front. Some believe the linked chain is as much to blame for the tensioners being eaten away as the spring tension. Probably good to monitor rear tensioner wear.
3) Upgrade your cam plate to an '07+ cam plate with conversion cams. This is an excellent choice. You get the new style cam plate with hydraulic tensioners, and o-ring chains front & back. You will need to buy a conversion cam and get a tune. Should be able to go well over 50K miles before inspecting for wear.
4) Upgrade to gear driven cams. Obviously it would take wear on the tensioners out of the equation. However, you MUST check your crank run out. Too much and the run out will destroy the gears... I've read it must be less than .004, yet many believe it should be less than .003. You obviously must buy a gear set, cams, and retune. If your runout is within spec, this would be the best choice... never check tensioner wear again!
It's a great bike (I have an '03 w/95" kit) and you should enjoy it for many years to come....
