Throttle?
Old Apr 6, 2018 | 11:42 AM
jumpnbean's Avatar
jumpnbean
Default Throttle?
Hello
thanks in advance for any suggestions.
2012 roadking juat slip ons all elae is stock.
when im cruising around 70mph or more and twist the throttle to gun it, it seems like it falls out of gear. The gear indicator doesn't show 6th and it sounds like its not in gear until I let off throttle and slowly increase speed. Any thoughts?
Old Apr 6, 2018 | 11:49 AM
Brewmany's Avatar
Brewmany
Slipping clutch?
Does the engine rev but not increase in speed, but stays in that gear? If so, I'd start at the clutch.
Old Apr 6, 2018 | 01:13 PM
ORradtech's Avatar
ORradtech
Yep, sounds like the clutch.
At a minimum it's time to adjust it. Might even need to replace it.
Old Apr 6, 2018 | 01:32 PM
harkon's Avatar
harkon
The gear indicator is basically a match between wheel speed and RPM. It's not truly a gear indicator beyond that. That is why when the clutch slips the indicator goes dark. By the speed match it doesn't fit a gear ratio.
Old Apr 6, 2018 | 03:43 PM
jumpnbean's Avatar
jumpnbean
Thank you guys for your response I'll check it this weekend
Old Apr 7, 2018 | 09:29 AM
kojak's Avatar
kojak
Does your bike have a hydraulic or manual clutch?
Norcalsvt
Jul 30, 2018 01:14 AM
W0ace
Dec 3, 2015 09:16 AM
Moondogger
Oct 10, 2012 09:38 AM
skulznflames
Exhaust System Topics
Jun 4, 2008 10:03 AM
ThePointman
May 1, 2008 10:20 AM
