I am instaling the security system on my 2011 street glide the instructions are very vague.I need to replace the turn signal module but am not sure where it is located.Also there is a antena that I am not sure about.Can you help me? Thanks
I found the module and replaced that.But I can’t see where to plug the other end of the antenna to.
Thanks for the help!
There is a tab in front of the battery that the antenna slides onto. It is at the top front of the battery and the antenna will sit parallel to the battery. Hope this helps, I added the security to my 2012 Ultra so if you have questions I might be able to help.
There is what looks like a connector cover with nothing in it.Is that what you are talking about?So maybe it doesn’t actually plug into anything?
