2014 street glide performance
Old Apr 18, 2018 | 05:06 AM
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by Bafflingbs
Have to disagree with those dissuading you against a cam upgrade. It’s worth it, but, you should really change your lifters and go to adjustable pushrods.
That's an excellent torque curve! Great stuff.
Old Apr 18, 2018 | 05:29 AM
mikeo33y's Avatar
mikeo33y
Originally Posted by White Glide
I got a 16 SG. I decided to stay away from cams for now. The money to power gain ratio wasn't there for me at the moment. Here is my dyno graph that was recently done with my set up. Just A/C, header pipes, slip ons and a good tune.
dont wanna hijack this thread but whats the deal with the boyesen power x. i love Boyesen products and used them in my mx bikes since the 80s. The guy was a great engineer and every one of there products ive used has always worked.
scott7d's Avatar
scott7d
I agree with the cyclerama 570. Pending you don't have a crumby exhaust to ruin it all, that cam with a good tune will perform like a (maybe even better) solid stage 1 110".
And if you can get it to Sheffer Performance, he knows that cam better than anyone. Overall a highly regarded tuner and great guy.
Old Apr 18, 2018 | 04:39 PM
Bafflingbs's Avatar
Bafflingbs
Originally Posted by GalvTexGuy
Say what you want about money to power gain ratio, but after upgrading cams. lifters, pushrods and a tune, my bike is a lot more fun to ride than it was before the upgrades.
Amen!
Old Apr 18, 2018 | 04:40 PM
Bafflingbs's Avatar
Bafflingbs
agreed
Old Apr 18, 2018 | 04:51 PM
Bafflingbs's Avatar
Bafflingbs
http://www.boyesen.com/power-x-intake
Old Apr 18, 2018 | 04:56 PM
RayHD11's Avatar
RayHD11
I already had the stage 1 completed... Hyper Charger/full Rush exhaust...2014 SG. I went with the HD SE-259 cam kit (#25482-10) and the Power Vision for the tuner. That set up gave me 91HP and 102 ftlbs torque. It's doing it's work between 2500 and 4500 RPM. You'll want to go with adjustable push rods and change out your cam bearing to the Screaming Eagle cam bearing...
Old Apr 18, 2018 | 06:06 PM
Dguy's Avatar
Dguy
If you look at a cam upgrade as numbers only you aren't looking at it the right way. It's all about the curve, not the final numbers. The curve is what makes it a different bike and makes it so fun to ride. I have 57's in my 2012 and did the work myself. I was very happy with the end results.
Old Apr 18, 2018 | 06:20 PM
INJEKTER's Avatar
INJEKTER
ok... well for the record....have always wanted a bit of a build on my bikes.... but i could never pull the trigger....... well this time i said F it and did a full stage 4...........could not be happier... im at 120hp /120 tq.......... the bike hauls ***..... zero regirts
Old Apr 18, 2018 | 08:40 PM
White Glide's Avatar
White Glide
I agree with everyone that in order to do a PROPER cam job, you should ABSOLUTLY replace the lifters pushrods. I am not denying that at all.
I also agree that it is not about the money to output ratio.
What I AM saying is that, much like the OP, I had to take a look at what mattered. OP doesn't want to want to change a lot of internals. He wants to stay stock there but put a cam in. So to me, that reads that there is budget in mind. When I get the money, I will ABSOLUTLY to a cam job with all supporting internal mods that should and need to be done.
So if it comes down to budget, wait the cam out until all other parts can be purchased and installed.
If I am reading into that too much, please forgive me and I will shut my trap. It tends to get me into situations.......
