Heat shield fix
Old Apr 28, 2018 | 01:38 PM
TB589's Avatar
TB589
Default Heat shield fix
The bracket for the hose clamp on the center exhaust heat shield of my 16 Street glide came off at the welds.. Don't know how. Has anyone used the JD Weld or other high temp glue on the heat shield? welder says it would discolor the shield and may start it cracking...Any other suggestions???
Thanks.
Old Apr 28, 2018 | 01:44 PM
Ed Ramberger's Avatar
Ed Ramberger
They're tack welded then chromed. I doubt you can glue it back on. Was the clamp way overtightened?
Old Apr 28, 2018 | 01:49 PM
bagga's Avatar
bagga
drill a hole through the bracket and heat shield. go to a hardware store and get a small screw, lock washer and an acorn nut in stainless steel. put the acorn nut on the outside.
Old Apr 28, 2018 | 04:06 PM
TB589's Avatar
TB589
No it wasn't over tightened, may have been loose though. Maybe rattled loose...
Old Apr 28, 2018 | 04:10 PM
kojak's Avatar
kojak
You can find take off heat shields oretty cheap online. Just get another set and be done with it.
Old Apr 29, 2018 | 06:36 AM
flhxkiller's Avatar
flhxkiller
I went the small screw and nut route too. Been that way a couple years now, no issues.
Old Apr 29, 2018 | 01:45 PM
67Shuv's Avatar
67Shuv
My front heat shield just did this. Found a set of nice take-offs from a member here and currently waiting on them to ship. The plan is to run the nicer of the two sets with the good front shield and repair the broken one (I'll try brazing it) and have a set powder coated. Figure out which set I like best and shelve the others for a rainy day.
Old Apr 29, 2018 | 10:02 PM
Ed Ramberger
After you braze it, black grill paint baby...
LQQK_OUT
Jul 28, 2025 02:49 PM
Speedspeed
Nov 30, 2016 10:15 AM
Dr. Tiki
Oct 5, 2013 08:44 AM
cdestuck
Mar 8, 2013 05:05 PM
Dru
May 15, 2008 10:14 AM
