FatCat PCIII Map
Old Jun 23, 2007 | 09:12 AM
Kern's Avatar
Kern
Default FatCat PCIII Map
I have been looking all over trying to find a canned D&D FatCat PCIII map. Anyone know where I could find one? Nothing on the website.
Thanks.
Old Jun 23, 2007 | 09:38 AM
DocHarley's Avatar
DocHarley
Default RE: FatCat PCIII Map
This any help?
https://www.hdforums.com/m_196131/tm.htm
Old Jun 23, 2007 | 10:12 AM
BikerSingle.com's Avatar
BikerSingle.com
just search it at google
Old Jul 1, 2007 | 09:12 AM
Kern's Avatar
Kern
I have tried to trick Google several different ways searching for a map for the FatCat. Nothing comes up for a FLH.
With all the guys using the FatCats here now, what maps are you running with your PCIII? Would you be willing to share it?
Old Jul 1, 2007 | 09:17 AM
maineultraclassic's Avatar
maineultraclassic
I would try one that matches your build, and uses the Bassani Road Rage for exhaust. The Road Rage has the stepped header design and equal length pipes just like the FatCat. The mufflers on both of them are probably pretty similar too. That will give you a starting point to work with, then you can play with it a bit or just get it dynoed if you have to have it at 100%.
Steve
Old Jul 1, 2007 | 09:32 AM
rollover's Avatar
rollover
What's your build?
Old Jul 1, 2007 | 09:39 AM
Kern's Avatar
Kern
Just air,PCIII and pipe for now.
2006 SG
88"
D&D Fat Cat 2into1
Ness Big Sucker
PClll
Old Jul 1, 2007 | 09:46 AM
rollover's Avatar
rollover
email address?
Old Jul 1, 2007 | 09:53 AM
maineultraclassic
ORIGINAL: Kern
2006 SG
88"
D&D Fat Cat 2into1
Ness Big Sucker
PClll
Map 807-226 is what I would try out if you can't find anything else.
Steve
Old Jul 1, 2007 | 09:55 AM
Kern's Avatar
Kern
ORIGINAL: rollover
email address?
PM'ed you rollover.
Thank you much.
-Kern
