Capacity
Old May 13, 2018 | 02:59 PM
kel03's Avatar
kel03
Originally Posted by Guntoter
7 replies with 7 different answers. I bet the OP learned something today!
I bet he knows the answer and just testing everyone............
Old May 13, 2018 | 03:17 PM
CSMHOG's Avatar
CSMHOG
I guess if you want to technical, the op asked what the capacity was ... the capacity won’t change with or without a filter change. How much you add will ... the capacity will ALWAYS be 4.0 quarts. The manual specifies to add 3.5 quarts after draining the oil with a filter change, I always low ball that number by half a quart and adjust after I check the dipstick.
Old May 13, 2018 | 03:38 PM
jmeyer58's Avatar
jmeyer58
Ragtop, did you round up or down? 😉
Old May 13, 2018 | 06:37 PM
Guntoter's Avatar
Guntoter
No need to "know" or "test" anyone since the previous 7 out of 7 replies covered nearly every capacity known to man between 3 and 4 quarts including at the microscopic fractional level. No way can I compete with that wealth of knowledge. Its on the same level of expertise as the scientific community has given with "Global Climate Change" so I am way out in the outfield of knowledge on this one so i just sit back and learn.
Old May 13, 2018 | 07:06 PM
RANGER73's Avatar
RANGER73
3 quarts. Including filter. Never fill to max capacity and there’s always some left in the case.
Old May 15, 2018 | 02:52 PM
dakotared's Avatar
dakotared
Originally Posted by Ragtop
3.56726 qts approximately..
didn't you mean 3.141592653589793238462643383279502884197169399375 10582097494459230781 ?
Old May 15, 2018 | 03:35 PM
BobFLHT2002's Avatar
BobFLHT2002
now I want pie...
Old May 15, 2018 | 04:57 PM
Zerk's Avatar
Zerk
Never heard 3 quarts before. Is that softails with seperate oil tank under seat? Touring bikes is 3.5- 4. I believe owners manuals for my own says 3.5 and service manual says 4.
Many people run the 1/2 quart low. I usually start with 4 a let it blow out.
ntg433
Milwaukee Eight (M8)
24
Nov 6, 2018 01:19 PM
grumpy56
Jun 18, 2018 07:43 AM
SnoRider
May 16, 2018 10:36 PM
Dannyrk02
May 12, 2018 07:22 PM
IRON1250
EVO
20
May 8, 2018 02:37 PM
