Cruise scare 😑
Old May 14, 2018 | 09:38 PM
GittinThere's Avatar
GittinThere
Originally Posted by OldEnuf2NoBtr
It does absolutely every single time that Iv'e used it on my 2012 FHLX.
Wasn't referring to yours! Lol.
Old May 14, 2018 | 11:41 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by GittinThere
Would you be kind enough to give a little more 'how-to' on this stepper cable? Where exactly is it relative to the throttle cables? Or is that the stepper cable...? Still learning!
The Cruise Module (#6) is behind your Left Side Cover and the Stepper Cable (#5) runs to your Induction Module (EFI)
https://shop.outpostalaska.com/OEMpa...CRUISE_CONTROL
Old May 15, 2018 | 07:56 AM
ORradtech's Avatar
ORradtech
It does absolutely every single time that I've used it on my 2012 FHLX.
Then yours is working properly.
He has tried and it does not release the CC therefore his has a problem that he is trying to address.
Old May 15, 2018 | 08:23 AM
Tarkus60's Avatar
Tarkus60
you can still get the cable from HD. I bought spares for my 2002.
This manual is needed in my opinion. This just a quick example you can get it cheaper.
https://www.diyrepairmanuals.com/pro...6a9-qO4ipYOwgZ
Old May 15, 2018 | 09:57 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Out of curiosity, when you flip the power switch off and it changes nothing, what shows up on the display? Does it stay lit? Or does the light go out? And, I suppose, what color is it?
If the unit is powered off, then friction really can be the only thing holding it in place.
In my experience with mine, if the cruise control unit is not properly calibrated, it can be quite aggressive in how it responds to resume or to speed loss.
Old May 15, 2018 | 11:25 AM
GittinThere
I'm going to have to do it again! I can't remember ��
I'll post back here perhaps later today - but thanks for your interest.
Old Jul 1, 2018 | 10:05 AM
GittinThere
This bike has cables not DBW.
I know it's been a while since this thread was active but in all honesty, I've simply not bothered with using the cruise. Until...Recently I got up the nerve to try it again and again and here's what happens:
1. Turn on CRUISE switch - switch light on (red)
2. SET button does indeed lock in - green 'C' comes on on the tach dial face
3. Touching BRAKE or CLUTCH does cause the green light 'C' to go out BUT DOES NOT ALLOW THROTTLE TO ROLL BACK. I can, and do of course, physically roll it back to essentially disengage cruise.
4. RESUME works BUT it does not stop accelerating until I stop it. Now....
Not sure if something I noticed when changing my grips has anything at all to do with it but here's the deal. When removing the throttle side grip I had a difficult time getting one side of the cable out of its retaining slot/hole. The cable I'm I'm referring to was the forward one - best to my recollection. The rearward cable had plenty slack to allow removal but not the other one. Wondering if that cable was longer(?) it might behave properly by 'releasing'? Thoughts?
Old Jul 1, 2018 | 11:20 AM
FatTony's Avatar
FatTony
Considering the fact that you can physically roll the throttle off when the cc is stuck i'd say we're here....
Most likely a stuck cable issue by the sounds of it.
Old Jul 1, 2018 | 01:20 PM
GittinThere
Originally Posted by FatTony
Considering the fact that you can physically roll the throttle off when the cc is stuck i'd say we're here....Most likely a stuck cable issue by the sounds of it.
I think I might be on the right track here! It just seems logical to me now since that throttle cable just simply seems to get stuck even though all other functions seem to be working properly. Oh well, just another bullet point on a list to check off. Thanks
Old Jul 1, 2018 | 02:40 PM
Guntoter's Avatar
Guntoter
The "stepper cable" can be removed and lubricated, the same thing that should be done on all cables yearly. Once all the cables are properly lubed and it still is doing this, it most likely is the cruise control unit, which I believe are no longer available. For whatever reason H-D decided to discontinue production of the cruise unit for the cabled bikes.
I had the almost same problem with my cruise control on the way to Sturgis in 2012. It would also not shut off with the brakes, it would while the brake was applied but as soon as you let off the cruise would re-engage and start running away. Turning off the main switch did shut it down though. Main problem was the cruise usually did not work but occasionally would engage then try to run away. Was frustrating and dangerous. I bought the H-D electrical manual, which has the diagnostics for the cruise, and went through everything 3 times and nothing showed bad. Eventually I spent the big bucks (near $300 if I remember correctly) and replaced the main unit, but it still did the same thing. Stopped using it and a few months later tried it again and its worked fine since.
One thing you can try is disconnect the battery for about 30 seconds (or maybe remove Maxi fuse for a bit) then reconnect and see what it does. I think the computer stores the malfunction in it's memory so maybe "rebooting" it may help. It sure can't hurt.
