Auto Shut Down?
Old May 15, 2018 | 05:04 PM
freeman73's Avatar
freeman73
Default Auto Shut Down?
I was on the motorcycle a couple hours today in hot weather. While I was riding down the road, it completely shut off. No power to anything. It was like someone turned off the ignition switch. I pushed it to a shaded area and checked all the fuses. After about 15 minutes, turned the ignition on and everything lit up. It started but wouldn't idle to I turned it off for another 5 minutes or so. It started without issue and hasn't had any issues since. Did it just overheat and trigger a safety auto shut off?
Old May 15, 2018 | 05:09 PM
MURPHCC1's Avatar
MURPHCC1
Year and model?
Yea.......that doesn't sound good!!
(they don't all do that...)
Check all the primary cables from battery to starter to fuse box....clean and tighten with dielectric grease....
I still have no clue but ya gotta start somewhere......never heard of that......
Old May 15, 2018 | 07:00 PM
Veekness's Avatar
Veekness
I've heard of it but until I know what model it is, why venture a guess? My guess might not apply to what the OP has...
Old May 15, 2018 | 07:05 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Years ago some touring bikes would do that when the main circuit breaker would heat up, thermal breakdown. A TSB was issued to change the C/B and even going up one level from the standard amp rating, for example 35A up to 40A. With that being said check with your dealer on this.
Old May 15, 2018 | 07:18 PM
Ed Ramberger's Avatar
Ed Ramberger
rather than continue to answer this in different threads read this and I believe you might have an answer
https://www.hdforums.com/forum/ignit...eed-03-ug.html
Old May 15, 2018 | 09:46 PM
danzio's Avatar
danzio
This happened to me one time while riding my '04 Dyna years ago. It only happened once, never to repeat. I chalked it up to my lazy Gremlin Bell.
Old May 15, 2018 | 10:22 PM
freeman73's Avatar
freeman73
Sorry all. Thought I had my signature set up. I have a 2003 Road King Classic
Old May 16, 2018 | 01:33 PM
DAVENRINO's Avatar
DAVENRINO
That may be in the year range. My 2000 did it a few times. Replaced Main circuit breaker as mentioned above.
Old May 16, 2018 | 02:02 PM
roussfam's Avatar
roussfam
Yep, that's when they were having problems with a weak main breaker. Have your dealer run the VIN to see if it was ever changed.
Jim
Old May 16, 2018 | 05:22 PM
lt1-xjs's Avatar
lt1-xjs
Hopefully the main breaker, easy fix. Also check and see if it has a Power Commander tuner as some of those had issues displaying the same symptoms.
