Starting issues need advice
Old May 24, 2018 | 01:13 PM
Bloodyvapor's Avatar
Bloodyvapor
Stage I
Default Starting issues need advice
I recently bought a 1995 ultaglide. The guy I bought it off of had it running for me but it took some effort to do so. Now I got it home I found out I don't have any spark. I ordered a new coil. Now I found out I'm not getting fuel. Does antone know what the reason could be? The guy I bought it off of was the 1st and only owner, it only has 30,000 miles and was taken care of but sat for a year. He put seafoam in the tank and oil. After I try the coil, what should I do to get the gas flowing? Is it just blocked up from sitting? Thanks for reading and your suggestions are very appreciated. I'm new at this...ty.
Purple rain i know lol
Old May 24, 2018 | 09:21 PM
SpiderPig's Avatar
SpiderPig
If you have a CV carb your fuel petcock is vacuum operated. Check to see if you have a vacuum line attached to the petcock and apply vacuum and see if fuel flows. This might be your issue if you have a cracked line not allowing any vacuum allowing the valve to open.
Old May 24, 2018 | 10:42 PM
Zerk's Avatar
Zerk
1 year with seafoam, I wouldn't think would be a big deal. Lot of stuff sits 6-8 months without it. At some point I would pull the carb and clean it if it doesn't go. If you got spark, then you need fuel.
I would also dump all the gas and just start fresh.
Old May 24, 2018 | 10:47 PM
SnoRider's Avatar
SnoRider
Did the coil correct the spark issue?
Robottom
Dec 12, 2018 01:44 AM
Andrew Buckley
Jul 5, 2018 02:38 PM
Dergs713
EVO
82
Sep 18, 2012 05:11 PM
JigokuNoIkari
Apr 1, 2012 01:11 AM
scorcher2005
Mar 31, 2009 06:33 AM
