Brake lights
Old Jun 7, 2018 | 11:54 AM
Varkp's Avatar
Varkp
3rd Gear
Originally Posted by RIPSAW
11.38 is showing a lot of resistance from somewhere. Should be battery voltage of around 12.6. See if that 11.38 has enough amp to light one of those bulbs with jumper wires.
I just read it again it was 11.8. I’ll check that next. I will also check the bulb again just to be sure. Thanks
Old Jun 7, 2018 | 12:05 PM
Varkp's Avatar
Varkp
3rd Gear
I checked the voltage to the plug that goes to the tour pack and it shows the same voltage. That voltage is enough to trigger the lights in the tour pack, I’m lost.
Old Jun 7, 2018 | 12:23 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Did you measure that 11.8 on the tail light filament contact or the brake light filament contact? It makes a difference.
For clarity, does your tail light work? Or is that out too?
Doesn't take much corrosion on a bulb base or in the bulb socket to render it inoperable.
Old Jun 7, 2018 | 01:49 PM
Jackie Paper's Avatar
Jackie Paper
Obiviously you have starting voltage. Check your voltage at battery and on the cable that hooks to battery.
See what that is to compare.
lpj21112
Jan 20, 2021 11:55 AM
sixgun95
Jun 30, 2019 11:24 AM
Mike62Jazz
Jun 1, 2019 07:15 PM
Danthern
Apr 15, 2019 02:34 PM
canolg
Sep 17, 2013 10:29 AM
