I have a 2010 Ultra Classic with 70K on it. Every 300 miles or so I get a very loud clicking sound seemingly from the top end. The sound is much much louder than the typical tappet click that the engine has, It almost sounds like a lifter has collapsed and the pushrod has a lot of play in it. This only lasts for a few seconds then goes away. It happens mostly when the engine is warm and can occur at all speeds. I have replaced the lifters and pushrods with S and S parts but this did not stop the clicking. The bike has been well maintained and I have run Mobil 1 it is for years. Any ideas???? I'm stumped. I thought for sure it was a bad lifter that was bleeding down, but when the new lifters did not solve the problem I am back to square one.
I thought the same thing at first, but he said it's only every 300miles or so. My bike had the constant sewing machine sound up top at the rockers, I added rockouts and they work great. But the sound was always constant, so I think this is something else.
1. Does the sound change with load or throttle? Mine does, which contra-indicates anything to do with the valve train.
2. Does the sound change with rpm change? Mine only sorta does, which really baffles me. The higher I rev the engine, the louder my ticking will get, but not very much faster.
My noise isn't exactly like yours, but is similar. As my engine revs up, it starts playing the castanets. Going down the interstate, sitting upright, it's like I've got a flamenco dancer between my knees. Lean forward or to the side to find it, and it disappears. Downshift and the castanet clatter gets louder, but not much faster. Roll off the throttle and it quiets. Similar with opening the throttle wide open, it quiets the clatter (but not as much as rolling off the throttle does).
I'm suspecting more and more my noise is either a fuel injector or even perhaps a weird acoustical property of my intake. Mine has done this since I got the bike some years ago, with no change or failure.
Oh, if I take off the windshield (Road King), it's gone as well. So reflection is playing a big part of the game.
I did install the rockout thingies. Made no difference.
LOL and I thought my noise was difficult to track down. No, the noise does not change but it is engine speed related meaning the faster the engine rotates the faster the sound. I don't think is the rocker arm because it is so intermitant.. The mystery continues.
Robb the Rockouts will fix your issues. The rocker arm tick on mine wasn't constant either but after the installation of the Rockouts the ticking never came back. It's a cheap fix.
If I can answer any questions or help in any way just holler
John @ Rockout
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Had the same loud ticking as the OP. Replaced the lifters and installed S&S adj push rods but resulted in no joy. Same year bike no oil burning or smoking. Picked up a set of Rocker Lockers from John and while tearing down to install them I found the issue. It turned out to being a torn valve stem seal on the rear exhaust valve. The top of the torn seal would move up to the top of valve stem occasionally and cause the loud ticking. Replaced the stem seals and installed the Rocker Lockers and it's all quiet now.
