Air in rear shocks
Old Jun 25, 2018 | 06:53 AM
Bikerpipes's Avatar
Bikerpipes
Default Air in rear shocks
What are most people running for air pressure in rear shocks in a ultra limited 2012 riding mostly solo.
Old Jun 25, 2018 | 07:30 AM
Road Gliderman's Avatar
Road Gliderman
Just did oil change on mine used Bel Ray 7w I now run 35lbs with two up and it feels pretty good.
Old Jun 25, 2018 | 09:07 AM
1HD1C's Avatar
1HD1C
depending on your weight 25-30 and make sure you use a hand pump.. I bought one off of ebay a number of years ago because it does 1lb increments
Old Jun 25, 2018 | 10:02 AM
rfulford's Avatar
rfulford
40 lbs with the hand pump. Mine has a slow leak someplace and will leak down a little after about a week. So I usually put a little in it when I check my tires.
Old Jun 25, 2018 | 10:48 AM
OldPhat's Avatar
OldPhat
I ride my 2014 FLHX solo 100% of the time, so when I add air I use about 15 pounds in the 12inch shocks.
John
Old Jun 27, 2018 | 02:49 PM
Rahlstin's Avatar
Rahlstin
16 FLHTK, Stock air ride. Changed out RR shock oil to 5w Belray HVI. I'm 240lb. I run 22-30 solo depending on the road, very very smooth. With wife n gear, 55-60. (50 just wasnt enough cushion)
Old Jul 3, 2018 | 05:09 AM
grbrown's Avatar
grbrown
From the above we can see that you should pick a number, try it and adjust to your liking from there! Many of of us have had to do the same, as ride comfort is a very personal thing. If you don't have the owners manual, you can download one from the H-D website, go to the Owners tab. That will give you the official guidelines for your model - recommended shock pressures have changed over the years.
Old Jul 3, 2018 | 05:46 AM
alarmdoug's Avatar
alarmdoug
Always 40 to 50 Lbs, HD hand pump. Fair amount of two up riding, me 180 and wife 120.
Pretty much, fill to 50 lbs whenever I attach the hand pump a few times a year.
Old Jul 3, 2018 | 06:00 AM
Kingglide549's Avatar
Kingglide549
Agreed
Alohacmc
Air Suspensions
Sep 24, 2017 02:36 PM
nhrider1
Jul 15, 2016 06:01 PM
89FLHTC
EVO
Feb 26, 2016 05:47 AM
Bullitt59
Jul 31, 2013 11:28 AM
desertwolf
Oct 11, 2010 03:30 AM
