Rough Idle
Old Jul 8, 2018 | 02:29 AM
NELS's Avatar
NELS
IAC = idle air control
Old Jul 8, 2018 | 04:51 AM
Hoginedgewood's Avatar
Hoginedgewood
it’s about $70, sits on top of the throttle body, it doesn’t like breathing oil mist.
Are you venting the heads into the intake?
Old Jul 8, 2018 | 07:11 AM
07_Dyna's Avatar
07_Dyna
In another thread I found using search it says to use some spray type throttle body cleaner on it - spray the stuff into the port while blipping the throttle. What you use must be sensor safe - you can end up killing your o2 sensors...
I'm gonna try that today. Stay tuned
Old Jul 8, 2018 | 08:09 AM
tpcowfish's Avatar
tpcowfish
When i owned an 06 SG, i had work done to it, it just kept backfiring, ect. Finally stopped at Roeder's, in Monroeville, a motorcycle shop, on the way home for a trip, they were closed , but Jess Roeder, came out, took my imfo, had a message before i got home. HD had a tech bulletin about the injectors. They were the wrong angle from the factory, Had em fixed, changed, bike ran great, I don't know if this is your issue, but thought i would throw it out there, Good luck
Throttle1971
Milwaukee Eight (M8)
19
May 13, 2019 06:33 PM
tommnyc
Apr 29, 2014 08:54 AM
scotsport
Sep 21, 2013 03:43 PM
bkessler28
May 18, 2013 12:25 PM
zz rocker
Oct 30, 2010 04:13 PM
