Front pads rubbing
Old Jul 8, 2018 | 11:18 AM
EdwardK's Avatar
EdwardK
Another response suggested checking the rotors for heat. I wouldn't recommend reaching down and grabbing a rotor after a ride unless your into pain. Brakes use friction to stop. Friction generates heat. If you just went for a ride and used the front brakes to stop, I guarantee they will be hot to touch.
As others have mentioned, based on the age and low mileage on your bike, the calipers are probably sticking a little. Easy to remove the calipers, pry off the pads, and clean the pistons. There are several how to videos on you tube. It's also possible you have a warped rotor but you would feel it surge when you stop.
Of course there is a good possibility your friend may have been hearing things and nothings wrong,
Clean the calipers. It's easy, cheap, and can't hurt.
Good luck.
Old Jul 8, 2018 | 11:31 AM
GittinThere's Avatar
GittinThere
Originally Posted by EdwardK
Another response suggested checking the rotors for heat. I wouldn't recommend reaching down and grabbing a rotor after a ride unless your into pain. Brakes use friction to stop. Friction generates heat. If you just went for a ride and used the front brakes to stop, I guarantee they will be hot to touch.....
Good luck.
Thanks for the heads up but I am smart enough to understand that they could burn me!
Old Jul 8, 2018 | 12:20 PM
OkieBill's Avatar
OkieBill
There are no vents on your stock 2003 brake calipers. Mine are identical since they’re the same year.
I ended up making the cleaning procedure a 6 month PMI along with fasteners. It just gives me another excuse to wrench a little when I can’t ride.
Old Jul 8, 2018 | 01:48 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Most double disc front brakes rub a little but not too mush heat.
Old Jul 8, 2018 | 08:05 PM
GittinThere
Took it for a ride this evening and put around 20+ miles on it. Got back and checked the rotors temp and both were certainly tolerable to touch. I THINK one of the rotors was a tad warmer than the other....
I have watched a couple YouTube vids and seems straightforward to remedy the problem...
Old Jul 8, 2018 | 10:44 PM
Veekness's Avatar
Veekness
Originally Posted by Cygnusx51
Spray them liberally with brake fluid and give them a scrub with an old toothbrush...
A real man would use his regular toothbrush.
Just sayin'...
(Just joshin' ya, boy...I say, just joshin' ya!)
Old Jul 8, 2018 | 11:24 PM
markwolula's Avatar
markwolula
When your washing your bike , give calipers a good spray with brake cleaner , then rinse off with water … If you have a air compressor , give calipers a blast …. This will remove brake dust and grime that may have built up etc.. If you apply the anti squeal paste on the back of pads ,, the paste may be removed quicker , but I don't think it lasts all that long anyway, to have any negative results....
The above procedure will solve most pistons from sticking from brake dust and grime.... When its time for new pads , and or flushing brake system,, that's the time to properly clean the caliper /pistons etc ….
Of course if you do a lot of miles,, giving your calipers/ pistons a good clean , say once a year would be a good idea ….
Old Jul 9, 2018 | 12:33 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Originally Posted by GittinThere
Would I need to remove the pistons from the calipers or is the cleaning more superficial on the outside of them? If so, a good spray brake cleaner to do the job? Thanks.
Have someone do it for you. Brakes aren't something to mess with, especially if it's all new to you. 22K miles in 15 years? Wow. Again, have someone do it for you. Or, at least show you how to do it.
Old Jul 9, 2018 | 02:09 PM
GittinThere
What is this bolt head style called? AND.... while we're at it, what size am I looking at here? 15 mm? Thanks
Old Jul 9, 2018 | 02:21 PM
matt_eglide's Avatar
matt_eglide
That mounting bolt is 10mm and is a 12 point. You must use either a 12 point 10mm wrench or 12 point 10mm socket to remove it. Don't try it with any other size or you'll strip it all to hell and make removing it impossible. If it's been a while since you last had that bolt out, may be on there pretty good. I recommend a long breaker bar to get it loose, can't remember the torque specs when putting it back together though. HTH
