No Front Turn Signals
Old Jul 12, 2018 | 07:16 AM
Bowhunter61's Avatar
Bowhunter61
Default No Front Turn Signals
OK just noticed I have no front turn signals. Here is the setup I have:
ProBEAMŽ Amber/White Dynamic Ringz SKU: PB-AW-1157
Standard Smart Signal Stabilizer SKU: GEN2-SSHD
GenesisŽ II Laydown LED Taillight SKU: GEN2-LDW-S-B
GEN-200-R-1156™ Red 1156 Rear Bullet-Style H-D™ LED Inserts SKU: GEN-200-R-1156
The front ProBeam's have a white light circle when the signals are not activated and when you activate them they go to Amber.
Rear signals and brake light work just fine.
All of this worked fine before heading out on our trip last week to Kentucky.
So I checked the codes and came up with B1121, B1122, and B1154
B1121(TSM) Left Turn Output Fault
B1122(TSM) Right Turn Output Fault
B1154 Clutch Switch Input Short to Ground
I am going to take a guess that the Clutch Switch input short to ground could be my problem. But I cleared the codes and none of the codes came back, I just cleared them in the parking lot at work and then started the bike up. How long before the code would be registered again?
What I do notice now is the left front turn signal the white amber ring is partially on but flickers. This tells me I have a short some where.
So, any suggestions on best way to track this down?
Old Jul 12, 2018 | 07:54 AM
Bowhunter61
So after doing some reading I found out that the B1154 code can be set by coasting with the clutch pulled in for over 10 seconds. I believe I did this on my ride in KY last week. So this may not be the issue at all.
Old Jul 12, 2018 | 11:14 AM
Bowhunter61
Found the issue. I was on a trip last week to KY to do the bourbon tours and some riding southern KY. We got caught in some good rain 3 out of 5 days in the afternoons, some downpours.
I pulled the lens caps off and took the LED lights out and water came dripping out. The back of the LED modules was dripping wet. I had already contacted CD to get their opinion on what I should look for and the customer service suggested pulling the modules and looking at the back and sending pictures. Sounds like they have seen this before. They already have 2 new LED modules/turn signals shipped to me to replace these. GREAT CUSTOMER SERVICE!!!
The Customer service rep said the new ones will have conformal coating on the back of the board to protect it against moisture.
I still worry about the 1157 sockets and them getting corroded so I may use a dab of dielectric grease or I may silicon around the edges of the housing to get a better seal so no water gets in there.
sdeck86
Feb 22, 2015 04:53 AM
banditgrrr
Electrical/Lighting/Alarm
May 4, 2014 08:20 PM
Blaster06
Aug 12, 2013 10:30 AM
HarleyX89
Mar 18, 2012 03:30 PM
RRMC_YAA
Mar 19, 2011 11:30 PM
