Another TMAT question
Old Jun 27, 2007 | 04:02 AM
The Pawnbroker's Avatar
The Pawnbroker
Default Another TMAT question
How do I reset the settings that I may have changed while I was linked to the module back to the original? In other words, is there a way to simply reset all the tuning maps back to their original settings the way they were when I first loaded a map? I want to be able to tweak settings and then go back to the originals easily and quickly if necessary. I must be dense lately because I don't see this info in the manual.
If I load a map, I lose all the learned points is that correct? I guess it must be.
Could someone please explain how this thing works in basic terms? I think I have a pretty good understanding but could use a short tutorial.
I have read the Tuning Manual all the way through several times and still don't feel like I know what I'm doing to a great degree.
Please correct me if I am wrong about this. The main thing it is doing is changing the fuel being delivered by the injectors so that the actual AFR matches the AFR's that are called for in the map? So that while you are riding it is changing the settings for the injectors so that they deliver fuel in a way that provides AFR's that correspond to the AFR's in the various Tuning Maps?
In any case, a little help would be appreciated.
Thanks,
Dave
Gordon61
The Dyno Room
11
May 3, 2017 12:11 PM
MuddBugg
May 4, 2014 07:02 PM
kingomtn
11
Jan 23, 2013 11:42 PM
jaysonL
Mar 19, 2010 04:51 PM
fuct44
Aug 5, 2007 06:38 AM
