broken tranny dip stick
Old Jul 22, 2018 | 06:15 PM
ddunham's Avatar
ddunham
Stage III
Default broken tranny dip stick
removed tranny dip stick to add new fluid and it is broken. cannot find the broken piece inside tranny using scope.
scoped from top cover, drain hole and fill hole. the current length of dip stick is 2”. how big of a problem could the potentially be? how long is the OEM tranny dip stick? 2013 FLHX.
any info is greatly appreciated.
Old Jul 22, 2018 | 06:25 PM
run1fsr's Avatar
run1fsr
Have you removed the trans side cover? I suspect it may be hiding in there.
Old Jul 22, 2018 | 06:32 PM
ddunham's Avatar
ddunham
Stage III
run1fsr, thanks for the reply. are you referring to the clutch release cover?
Old Jul 22, 2018 | 09:07 PM
Ragtop's Avatar
Ragtop
Yes, the side cover. I wouldn't use the bike personally until I found the missing piece.
Old Jul 22, 2018 | 09:38 PM
run1fsr's Avatar
run1fsr
Yes, that's it.
Old Jul 23, 2018 | 07:28 AM
Riverside Joe's Avatar
Riverside Joe
If the dip-stick is metal, I'd try fishing with magnet probe also------------------------------------RJ
Old Jul 23, 2018 | 08:47 AM
SBates08's Avatar
SBates08
How about posting a pic of your broken dipstick. IMO if it's broken you've got bigger issues than just a broken dipstick.
Old Jul 23, 2018 | 08:50 AM
Iceman24's Avatar
Iceman24
This was a known issue w/that era's motor(s). I had two tranny sticks for my '09 FLHX...one to plug the hole (e.g. post saw'd off) & a 2nd to check fluid level. Hope you get the metal out...IMO - remove the side cover to crack 'er open & look for more damage.
Old Jul 23, 2018 | 10:52 AM
Spartanden's Avatar
Spartanden
the dipstick is plastic... no use trying a magnet!!
Old Jul 23, 2018 | 11:23 AM
smat45's Avatar
smat45
Just looked at mine...it was steel (metal)
Broke mine off a couple of years ago when I forgot to remove it when doing some trans work...it broke right off at the top of the bottom of the cap. I didn't replace it...just put in a qt after draining it...
smat
