Clutch housing
Old Aug 3, 2018 | 02:35 PM
jerryleejr's Avatar
jerryleejr
Originally Posted by gipper
Jerry: You mentioned that you just swapped your bars, so it's tough to say if what you have is indexed or not. I can't remember if my stock bars were or not; it's been so long since I had them. The bars that I now have is indexed on the left side though, but only you or the manufacturer of your new bars would know if yours is unless you're willing to mention what bars you now have. Someone helpful will eventually chime in, I'm sure.
it’s the Khrome werks 2+2 I figured if they were indexed the left would match the right in position. However after seeing that they don’t now I’m curious. I have zero issue adjusting it.
Old Aug 3, 2018 | 06:33 PM
big- mike's Avatar
big- mike
Adjust as needed to be comfortable
Old Aug 3, 2018 | 11:56 PM
Guntoter's Avatar
Guntoter
There are NO index marks. Where the levers sit is purely a judgement call. #25 Torx for the switch housings and #27 Torx for the lever clamp. Loosen both somewhat, position, re-tighten clamp then housings.
Old Aug 4, 2018 | 04:36 AM
Kingglide549's Avatar
Kingglide549
ALl that was already said and posted in #2 and # 5
lowrider19
Mar 6, 2019 07:57 AM
Lightngsvt
Milwaukee Eight (M8)
35
Jan 25, 2019 10:29 AM
Jcwilliams307
Jun 16, 2018 09:46 AM
dab102999
Jun 9, 2018 04:35 AM
hoethree
Feb 23, 2015 10:13 PM
