Hydraulic lifter install question
Old Jun 2, 2018 | 10:05 PM
Robb Liupo's Avatar
Robb Liupo
Default Hydraulic lifter install question
I have a 2010 Ultra with the TC 96 motor. After 70K miles I am replacing the lifters. The Harley Manual says to install them with the oil holes facing inwards, however, the lifters were installed at the factory with the oil holes facing outwards...Do I go with the instructions in the manual or do I install them they way they were installed from the factory? Any Ideas??
Thank You.
Old Jun 2, 2018 | 10:30 PM
skydude426's Avatar
skydude426
I noticed the same thing with my bike when I did the big bore this winter. I don't think it will matter. The oil flows around that slot and will enter the lifter no matter which way the hole faces. Just for no other reason than the manual said it, I put my new ones in with the hole inboard. They work just fine.
Old Jun 3, 2018 | 04:58 AM
Campy Roadie's Avatar
Campy Roadie
It doesn't matter.
Old Jun 3, 2018 | 01:37 PM
07_Dyna's Avatar
07_Dyna
Originally Posted by Nomadmax
It doesn't matter.
Just to play the devil's advocate here, reversing the lifter makes the roller rotate in the opposite direction..?
Old Jun 3, 2018 | 06:39 PM
skydude426's Avatar
skydude426
If you have the engine apart for some reason and are reinstalling the existing lifters, it's good practice to put things back together so they are in the same place and turn the same direction as before. If you're installing new lifters, it would make zero difference which way the roller turned.
Old Jun 3, 2018 | 07:44 PM
23Seven's Avatar
23Seven
Replacing OEM with OEM? Woods makes some good quiet lifters.
Old Aug 3, 2018 | 04:38 PM
Kingglide549's Avatar
Kingglide549
I have read Johnson Hi Lifts are supposed to be some of the best.
I have them in my bike with a 530 lift.
They are working............so far.
Old Aug 3, 2018 | 11:35 PM
Guntoter's Avatar
Guntoter
Comp Cams V Thunder lifters are low priced and high quality. I use them and no noise, no clatter on start up, even after sitting for 4-5 months, and work great. Does not matter where the hole faces.
Old Aug 4, 2018 | 01:05 AM
Peter Griffin's Avatar
Peter Griffin
Go on u-tube, see if you can find a video concerning this. My 2011service manual says to install lifters in the bore with oil holes on the inboard side and the flats on the lifters facing forward and rearward. I saw a video while back addressing that the push rod cannot be under pressure and must spin freely on the lifter otherwise something is wrong and you risk a bent valve.
Old Aug 4, 2018 | 05:10 AM
Kingglide549
A couple things here and presumption will ruin your day.
Pushrod thread count and the lifter and type you are using.
What am i talking about?
Different vendors have different pitch threads, so you cannot assume what HD says in a book for "their " adjustable push rods to be correct for what you are using.
You may have to measure how much your pushrod turns out per flat
You aso have to know what lifters are in there . Most want the piston centered, Johnson Hi Lift does not., solids want a fudge play or clearance.
Mberlin74
Engine Mechanical Topics
Jun 27, 2016 07:20 PM
timberland
Exhaust System Topics
14
Mar 24, 2013 10:59 AM
HDV-GLIDE
Nov 24, 2012 01:29 PM
John5395
EVO
Jan 13, 2011 04:11 PM
PhillHD1
Dec 1, 2007 02:33 AM
