2016 road glide rough idle
i removed the headers from bike ,made a rectangular cut,decat,then weld it,install headers on bike, didnt touch the o2 sensors, if its a bad o2 sensor then ill have an ecm code ,right? no ecm codes yet.
I don't remember if it throws a code or not. All I know is I once installed the O2 sensors backwards and my bike ran terribly when I went for a test ride. I knew right away what I had done.
Yass (08-27-2018)
You might want to see if one of the cylinders is missing at idle. Easy to do by pulling the plug wire while it is at idle. Pull both wires off and reinstall loose. Next get a jumper wire with large clips on both ends. This will be connected to the outside of the plug wire near the boot, other end connected to ground. This will collect the spark if it gets out the boot as you pull the wire off while the motor is running, otherwise it will knock you dick in the dirt as you would be the easy ground. So fire it up and remove the wires one at a time , Notice which cylinder dies more than the other .If they both die about the same you may have a fuel or vacuum issue.
For fuel or vacuum issues pull the air cleaner so you can get to the throttle body. With a piece of cardboard about the size of the t-body start at the edge and slowly move the cardboard to cover the t-body opening. You are going to listen for the engine to speed up or smooth out as you slowly close of the t-body opening. Smoother running would indicate a vacuum leak.
Now we gona check for a fuel problem. With a can of 2+2 carb cleaner give a very light misting into the t-body . If one of the injectors is not providing enough fuel for smooth running the slight mist of carb cleaner will smooth it out. You can also use the carb cleaner to snoop around for a vacuum leak by misting between the cylinder where the intake manifold is.
You also need to do a compression check .
Kent
Kent
Yass (08-27-2018)
Kent
Kent
as for the vaccum leak i put a piece of cardboard on the TB ,the engine dies immediatly.
now engine off ,open the flap with a small screwdriver and spary some carb cleaner keep the screwdriver under flap start the engine ,bike went into limp mode with p0131,p0154,p2101.
codes cleared and tried to spray some carb cleaner into the TB without screwdriver ,engine started shaking like crazy with backfire.
ShockwaveTXB
06-16-2018 09:45 AM
Calvin1989
Exhaust System Topics
04-30-2013 12:55 PM
