side stand ..aka jiffy stand
Old Aug 11, 2018 | 07:25 AM
  #31
heybaylor's Avatar
heybaylor
Originally Posted by foxtrapper
It’s interesting to contrast the HD locking stand with various others.
Like Moto Guzzi and their darn near auto retract design, which is notorious for dropping bikes.
Or Honda and their rubber tab, designed to flick the stand up should you ride off with it still down.
Yamaha and others with the kill switch on the stand, letting you start the engine in neutral with the stand out, but killing the engine should you put it in gear.
as well the degree of lean, or not. The size of the footprint.
You’d think someone by now would have figured out a way to combine the best of these features to make a superb side stand by now. Aye, Harley’s is arguably one of the best, when deployed on a parked bike. But ride off with it extended and dive into a left hand turn... not so nice now that locking tab.
well, if you really look at the design , the spring pulls the locking tab out of the slot when the weight is off.
so that left turn with the stand extended will just kick it back to the frame. same as you kicking it back
Old Aug 11, 2018 | 07:40 AM
  #32
RollaMo's Avatar
RollaMo
Yep!
I have rolled my bike out of the garage many times with the stand "down". As soon as you lift the weight off the bike, the stand is no longer "locked".
Any type of contact with the ground while rolling forward and the stand just folds up.
Stop the bike, extend the stand, lean the bike over on the stand and the weight will cause the locking tab to engage.
On a slope the bike might move an inch or so if it isn't in gear. But as long as the bike's weight is leaning on the stand, that jiffy isn't going to fold up.
You can drag it all over the parking lot and it won't fold up.
Old Aug 11, 2018 | 07:59 AM
  #33
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Not my experience with my stand. It gets the tab in before it starts swinging back, so it’s locked down. That’s why I’ve thought about adding a rubber tab like Honda uses.
Old Aug 11, 2018 | 09:15 AM
  #34
heybaylor's Avatar
heybaylor
maybe your spring is weak, they do go bad ,or the pivot is dirty, the tab wouldn't help just contact a little sooner
Old Aug 11, 2018 | 01:59 PM
  #35
foxtrapper's Avatar
foxtrapper
could well be. I’ve only had one Harley, this one.
tried it out riding early on, thought if anything, it was a strong spring holding it forward. But, I can see it being a a dirty joint quite easily.
In in any case, the stand would slide on the pavement as I leaned or turned left and the tab go up into the slot, locking the stand.
That’s why some years ago when I was new to harleys and this forum I asked if there was a Honda like rubber tab available.
Never felt the need to further follow up on it. I did eventually clean up and lube the pivot, but I’ve never retested it.
Old Aug 14, 2018 | 07:57 AM
  #36
Sethc1020's Avatar
Sethc1020
Originally Posted by RollaMo
Yep!
Best piece of info right here, thanks RollaMo! I bought a 2013 RG Ultra a month or 2 ago and have noticed that the bike will roll slightly from time to time depending on position and it scared the life out of me. Now I can rest easy that this Hog isn't going anywhere! Thanks!
Old Aug 14, 2018 | 11:43 AM
  #37
wolverinehusky's Avatar
wolverinehusky
When I park I keep the bike in 1st gear as a safety precaution.
Here is my "complete noob" stand story though that is super embarrassing. I'm riding the first bike I've ever owned, and had zero idea what I was doing for the first few hundred miles (I survived!). I pull up to a gas station on my 3rd or 4th ride, and instead of leaning the bike to the left for the stand, for whatever reason I lean it right LMAO thinking the stand was on that side. Dropped the bike.
Old Aug 14, 2018 | 12:14 PM
  #38
Sethc1020's Avatar
Sethc1020
I always do the same when parking it, the only time its really ever rolled is when I take it out of the garage before work and start it while off the bike. Scared the life out of me a few times, was for sure it was going down!
Old Aug 15, 2018 | 04:44 AM
  #39
grbrown's Avatar
grbrown
Talking
You'll be fine - we won't tell anyone.....
river rat
Oct 27, 2022 06:49 AM
nuttbaggerr
Jan 24, 2016 05:05 AM
Jammin1
Aug 21, 2015 02:00 PM
Freewheelin Franklin
Sep 18, 2013 03:28 PM
Surfit
Oct 11, 2006 12:54 PM
