move electra glide handle bars
Old Aug 11, 2018 | 02:50 PM
rmsmith5299's Avatar
rmsmith5299
Stage III
Default move electra glide handle bars
can i move FLHTK handle bars closer
Old Aug 11, 2018 | 02:53 PM
dawg's Avatar
dawg
You can roll them down a little which may make them a little closer. Have to loosen the clamps. Don’t know if that will give you what you’re after though.
Old Aug 11, 2018 | 02:59 PM
rmsmith5299
Stage III
Thanks, I was hoping to be able to put some 2 inch extenders on
Old Aug 11, 2018 | 03:13 PM
dawg's Avatar
dawg
Extenders? If you mean risers, that won’t work on fairing bikes. You’re better off getting a set of bars to replace the stock, something like KW Sweepers or the like that brings the bars closer to the rider.
Old Aug 12, 2018 | 12:28 AM
run1fsr's Avatar
run1fsr
Old Aug 12, 2018 | 06:22 AM
OldMike's Avatar
OldMike
To get the bar closer and better wrist angle without looking like an ape, the KW 2+2 narrow sweeper is a VERY comfortable bar.
https://www.hdforums.com/forum/new-r...installed.html
Old Aug 12, 2018 | 09:50 AM
grbrown's Avatar
grbrown
You will be surprised just how much the stock bars can be moved, also how much they seem to change shape, as you rotate them in their clamps. As you turn them towards you they will also get closer. It's best done with the help of a friend, to support their weight as you slacken off the clamps, otherwise you won't know where they started from as they drop!
Old Aug 12, 2018 | 10:03 AM
jerryleejr's Avatar
jerryleejr
I just did this and made a world of difference...
JJ
Old Aug 14, 2018 | 09:05 PM
rmsmith5299
Stage III
how do i get to the bolts holding my bars on? I can't get the plastic cover off. The ignition switch is in the way
Old Aug 14, 2018 | 09:10 PM
b4etty's Avatar
b4etty
Default switch
yes you need to remove the switch to get to the bolts. should get a service manual helps alot
