Track-True
Old Sep 7, 2018 | 08:17 PM
  #51
fabricater's Avatar
fabricater
I had a brand new 2010 ultra limited that would wobble . I did not know what was causing the issue,and it showed up big time 2 up pulling a trailer in a long sweeper.Now I know what I was feeling. I now have a 2012 and have not noticed it wobble. I have not pulled a trailer with the 2012 yet. It looks like this will be going on it this winter. I would rather not ever feel the wobble and this simply put makes the bike safer. Thanks for the info.
Old Sep 7, 2018 | 08:37 PM
  #52
Sierra977's Avatar
Sierra977
Recommended for 2014 SGS?
Old Sep 7, 2018 | 08:40 PM
  #53
hbsoldier3's Avatar
hbsoldier3
I have True Track front and rear on my 2014 Limited, so yes.
Old Sep 7, 2018 | 09:32 PM
  #54
Sierra977's Avatar
Sierra977
hbs, Thank you for the insight.
A follow-up question. My motor has the SE +1.5 quart oil pan. Do you know if that is a problem with True Track front or rear?
Old Sep 7, 2018 | 09:46 PM
  #55
hattitude's Avatar
hattitude
I'm pretty sure your +1.5 oil pan will interfere with the True-Track in the rear.
There was a short time, were True-Track was offered with an oversize oil pan. It had the heim joint attach to a mount that was part of the oil pan...
It was available for a short time and then just disappeared... I believe it used a Baker +1 (or +1.5, don't remember) oil pan....
Old Sep 8, 2018 | 12:23 AM
  #56
23Seven's Avatar
23Seven
Went through everything on my bike before adding the TT. I even had my local stealer go over it.
Fall Out ✅
Bushings ✅
Tire Pressure ✅
Shocks ✅
Tires ✅
Dealer tells me I push it harder than it was intended.
My thought make it fun to ride or switch brands.
True Track made it fun to ride.
Old Sep 8, 2018 | 12:25 AM
  #57
23Seven's Avatar
23Seven
Now it’s an FLHRSS
Road King Super Sport!
Old Sep 8, 2018 | 03:40 AM
  #58
grbrown's Avatar
grbrown
Wink
Gentlemen, if you haven't discovered it yet, you may like to read my thread on bagger wobble, from way back. An oldie but goodie, which explains the rubber mount systems of our bikes. I don't recommend you read the entire thing, otherwise you'll be housebound for ages.
Old Sep 8, 2018 | 08:14 AM
  #59
hbsoldier3's Avatar
hbsoldier3
Patented 20-00-09 TRUE-TRACK TOURING
Improve handling and stability of '09' and later Touring Models. This unit also protects and reinforces lower cross member.
Unit presently not suited for any +1.5 oil pan - Fitment for stock 4 quart oil pan only
Old Sep 8, 2018 | 04:13 PM
  #60
23Seven's Avatar
23Seven
I’ll go with 4 qrts and stability over 5 1/2 and bucked off on the side of the road.
