Dumb PCIII question
Old Jun 29, 2007 | 12:12 AM
serverpimp's Avatar
serverpimp
Default Dumb PCIII question
They say there is no such thing asa dumb question but I think this is pretty close. [sm=icon_rtfm.gif]What does the value in the map represent? Is it percentage? For example the cell at 1500 RPM and 10% throttle positon is 14. Is that 14% more fuel? 14% higher on the fuel/air ratio? 14 more goblets of fuel going into the cylinder? [sm=chairshot.gif] 14 what?
Old Jun 29, 2007 | 12:43 AM
iclick's Avatar
iclick
Default RE: Dumb PCIII question
ORIGINAL: serverpimp
They say there is no such thing asa dumb question but I think this is pretty close. What does the value in the map represent? Is it percentage? For example the cell at 1500 RPM and 10% throttle positon is 14. Is that 14% more fuel? 14% higher on the fuel/air ratio? 14 more goblets of fuel going into the cylinder? 14 what?
Not a dumb question. The A/F table values are represented as percentages, more or less than the ECM is instructing the injectors to provide. So, "14" for 10% TP @ 1500 theoretically means it is providing 14% more fuel at that point. I've been told by a reliable source that these numbers are not exact, though, and are more for representing values relative to others on the same table.
The ignition timing table represents advancing or retarding the timing in degrees. For example, "4" for a given table block would be a 4° advance over ECM at that point.
Old Jun 29, 2007 | 11:49 AM
gunrunner's Avatar
gunrunner
Jamie at fuel moto said each point was 1%, add 5 points and you have added 5% more fuel for that setting. He also said if you want to richen up by range, low mid and high, use the three buttons on the pcIII and each has a value of 3% for each bar, add 1 bar up in each and youve richened up all ranges 3%.
Old Jun 29, 2007 | 12:24 PM
iclick's Avatar
iclick
ORIGINAL: gunrunner
DynoJet told me it was 5% per bar. I wonder who is right, Jamie or DJ?
Old Jun 29, 2007 | 04:09 PM
gunrunner's Avatar
gunrunner
ORIGINAL: iclick
ORIGINAL: gunrunner
If I had to bet, Id bet on Jamie, I've had those guys at DJ confused a time or two with simple questions.
2deuceguy
Mar 30, 2015 05:11 PM
GAstreetglide
Apr 27, 2014 09:30 PM
davidnewtonparr
Apr 20, 2010 07:04 AM
martin1
Jan 4, 2008 03:04 PM
alexcue
Jul 24, 2007 08:50 PM
