Won't Start
Old Sep 3, 2018 | 01:07 PM
forby's Avatar
forby
2nd Gear
Default Won't Start
I have a 2009 Electra Glide Classic. We got back from a long trip a month ago and haven't had time to ride since. I pulled the bikes out of the garage the other day and when I tried to start mine, it sounded like the starter is going but did not engage.
Thoughts?
Old Sep 3, 2018 | 01:11 PM
50pannmore's Avatar
50pannmore
Dead battery
Old Sep 3, 2018 | 01:17 PM
forby's Avatar
forby
2nd Gear
Has a full charge, I keep it on a battery tender.
Old Sep 3, 2018 | 03:36 PM
GalvTexGuy's Avatar
GalvTexGuy
Take it out, take it to an auto parts store and have it load tested.
Old Sep 3, 2018 | 03:38 PM
ORradtech's Avatar
ORradtech
Not necessarily an indication of a healthy battery. Pull the battery out and have it load tested.
While it's out clean and tighten both ends of all the power cables particularly the frame grounds and the heavy cable at the starter.
Old Sep 3, 2018 | 07:46 PM
dickey's Avatar
dickey
If the starter is going but ain't engaging, that ain't the battery. Starter ring gear mebbe.
Old Sep 3, 2018 | 07:50 PM
GalvTexGuy's Avatar
GalvTexGuy
Yeah, "starter is going" is a little vague. I don't know what that means.
Old Sep 3, 2018 | 07:54 PM
Kingglide549's Avatar
Kingglide549
Dead battery
Old Sep 3, 2018 | 10:22 PM
Vernal's Avatar
Vernal
How old is the battery? Put a volt meter on the battery and hit the start button. If the voltage is below 10v your battery is bad.
Check battery and ground connections and starter mounting bolts.
Old Sep 4, 2018 | 12:09 PM
DanHappy's Avatar
DanHappy
Is the FOB have a good battery as well?
Spitballing here...
