inner bearing race problems
Old Sep 7, 2018 | 01:14 PM
han V's Avatar
han V
4th Gear
Default inner bearing race problems
Hello,
I own an electra glide 2010.
First time inner bearing race problems after 20k km. I installed a Hayden chain tensioner and changed the outer bearing of the race of course.
Now 2e time again a bad race after 15k km. I can do the job myself to change the race but this is not normal I think.
I now changed the primary oil for ATF-ford ( thinner oil) en installed a race from S&S whitch can't travel to the seal.
What more can I do to make the bike reliable? Baker attitude chain tensioner? baker compensating sprocket?
Old Sep 7, 2018 | 05:21 PM
Biggzed's Avatar
Biggzed
The S&S race is the fix. I think you will be ok from here.
Zach
Originally Posted by han V
Hello,
Old Sep 7, 2018 | 07:14 PM
Ed Ramberger's Avatar
Ed Ramberger
Be sure you are using the Barbie surfboard and not the Barbie stairs when tightening the compensator and clutch nuts.
Old Sep 7, 2018 | 10:51 PM
Joe from So Cal's Avatar
Joe from So Cal
I'm not sure it matters but I use synthetic ATF (Dexron) in my Primary. Heat resistance.
Old Sep 8, 2018 | 08:19 AM
F150HD's Avatar
F150HD
Hello,
a little unclear, you changed the bearing back when AND the race at the same time? or just the bearing?
unclear why you'd think the Hayden or your comp would play into its failure?
Barbie comment above....how do you remove the comp and clutch? are you using the locking bar? or the little 'steps' that are advised against
not going to get into a fluid discussion, but I run F+, it works really well for me.
Old Sep 17, 2018 | 06:32 AM
han V's Avatar
han V
4th Gear
F150HD,
I changed the bearing inner race (S&S)and the bearing which is coming over the race sitting in the chaincase housing.
reading more about the problem i'am going to believe the real problem is coming from a bad compensating sprocket. Last week i added a 5th spring into the compensator facing out and the bike is like a dream. No more clunk, clink and a smooth ride. When i stop the motor a quit end and not a clunk.
Old Sep 17, 2018 | 07:57 AM
SBates08's Avatar
SBates08
Got any info on this spring you added? My comp is needing to be replaced as well.
Old Sep 17, 2018 | 08:39 AM
han V's Avatar
han V
4th Gear
I got the spring from my dealer. its the same one as the other 4.
Old Sep 17, 2018 | 10:32 AM
SBates08's Avatar
SBates08
So you left the original 4 in there and added a 5th? Sounds simple enough and far cheaper than a replacement comp.
I still think I'm going to replace mine with the Baker comp and be done with it.
Old Sep 17, 2018 | 12:26 PM
HD Bobber's Avatar
HD Bobber
Baker Comp and their attitude adjuster is the way to go. Had it on my Dyna and everything was solid and quiet.
