Rear Shocks Broken Weld
Old Sep 14, 2018 | 06:11 PM
RAWKING's Avatar
RAWKING
3rd Gear
Default Rear Shocks Broken Weld
Progressive Suspension 440 Seris I.A.S Shocks 13" chrome(440-4213c) on a 1999 Road King FLHRCI
I bought these shocks brand new about ten years ago for my 1999 road king flhrci. I never installed them until recently (ten years later) and within two months the suspensions lower bolt attachment eyelet (attaches to the swing arm) snapped off of both shocks.
Ive heard that I would need some sort of receipt as proof of purchase for warranty but I do not have it, as it was so long ago. Heres my stupid question.....should I take it to a welder and have them tig weld the lower bolt holes back onto the shocks?
Thanks in advance,
Opie FMMF
Old Sep 14, 2018 | 06:20 PM
ORradtech's Avatar
ORradtech
Sure, why not?
If they failed from a poor weld then a compitant welder should be able to restore their functionality. The chrome in the area of the welds probably won't survive.
Old Sep 14, 2018 | 06:24 PM
packmen21's Avatar
packmen21
Originally Posted by ORradtech
Sure, why not?
Old Sep 14, 2018 | 06:57 PM
run1fsr's Avatar
run1fsr
I'd first give Progressive a jingle on Monday ... ya never know.
Old Sep 14, 2018 | 08:14 PM
RAWKING's Avatar
RAWKING
3rd Gear
Thanks Fellas,
mill gove progressive a call and next hit the welder if not anything else. Much appreciated!
Old Sep 15, 2018 | 12:14 PM
Max Headflow's Avatar
Max Headflow
I would replace the shock, If you weld it the rubber insert will melt and fail. Were you running any kind of lower block?
Old Sep 15, 2018 | 03:01 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
With no proof of purchase and the purchase being over 10 years ago I would not expect much from the manufacturer.
Good luck
Old Sep 15, 2018 | 03:11 PM
Kingglide549's Avatar
Kingglide549
I can't tell you why they broke off only guess ,
First one is , was it made in China?
Next, you can tig it on without hurting anything if you have to.
Tig done in little incriminates puts out very little heat,
Old Sep 15, 2018 | 03:37 PM
bikerlaw's Avatar
bikerlaw
Progressive is a stand up company. The 440's and the 444's (what they are called now) come with a lifetime warranty, and are made in the USA plant in California. I'd be pretty suprised if they make a deal out of the receipt if you call them first, and ship them your broken shocks. I've run many progressive shocks, had warranty work done, springs swapped, and many times there was no reciept involved. Maybe things have changed, but I suspect they will take care of you.
https://www.progressivesuspension.co...-series-shocks
Old Sep 15, 2018 | 05:10 PM
run1fsr's Avatar
run1fsr
A few years back Progressive replaced a set of monotubes that I had purchased on eBay. I won them in an action from a seller that never installed … box had been opened. They parts sat in that box for two more years before I pulled my front end apart to install chrome lowers. Discovered then that Progressive experienced issues with some early production units so I gave them a call. Technical representative told me to send the monotubes to him for inspection / testing. One week later I found a brand-new set sitting at my door.
