POWER COMMANDERlll
Old Jul 1, 2007 | 10:51 PM
Bryan1724's Avatar
Bryan1724
Default RE: POWER COMMANDERlll
ORIGINAL: Fishguy001
I guess I don't feel silly that I didn't know to set the Throttle position.
[sm=welcomesign.gif]To the club. [sm=icon_cheers.gif]You know if they would tell you to do it in the Destructions we wouldn't have an exuse. But nowhere does it say to set the throttle posistion. [:@]
Old Jul 2, 2007 | 03:16 PM
nujohn's Avatar
nujohn
JUST FINISHED SETTING UP MY POWER COMMANDER,,, ALL SEMES WELL
"THANKS TO ALL" FOR YOUR ADVISE I GUESS THERE NOTHING LEFT TO DO BUT TO GO FOR A RIDE
LATER THANKS AGIAN
Old Jul 3, 2007 | 09:46 AM
Smurfshxt's Avatar
Smurfshxt
Bryan1724, I cant download the throttle positioning directions....POS computer doesnt have the software. Is there another way I can get the instructions? Can it be posted here ?
Thanks
Smurf
Old Jul 3, 2007 | 01:10 PM
LeeFLHX's Avatar
LeeFLHX
Smurf,
Couldn't get the formatting to work so this is the best I could do for you. The info is in the user's manual manual under the help menu. Look at power commander tools. Based on what I've read thusfar, the 0 throttle position is the more critical, but you should do them both.
Take care,
LeeFLHX
Menu Choices
2-24
S
ET THROTTLE POSITION
Select
Power Commander Tools 􀀡Set Throttle Position
The Set Throttle Position window allows you to re-calibrate your throttle position if
needed.
To reset both the closed and open throttle positions, ensure that the PCIII USB is
powered up and connected to the computer via the USB cable, then do the following.
1 Click
Reset.
2 Twist the throttle wide open and release.
3 Click
OK.
4 To reset only the Closed
or Open position do the following.
5 Click the arrow next to the Closed box or the Open box
6 Click
OK.
Figure 2-22: Set Throttle Position
Old Jul 3, 2007 | 04:28 PM
Bryan1724's Avatar
Bryan1724
ORIGINAL: Smurfshxt
Thanks
Smurf
Smurf, The same tutorial is on your CD that came with the PCIII.
Old Jul 3, 2007 | 05:04 PM
Taterdog's Avatar
Taterdog
ORIGINAL: Smurfshxt
Thanks
Smurf
Smurf, your laptop must not have Adobe Acrobat Reader loaded. It's FREE software, so just go to the Adobe site and download it. Quick and easy and you'll be able to download what you need from Dynojet.
Tater
Old Jul 4, 2007 | 02:45 PM
Smurfshxt's Avatar
Smurfshxt
COOL!!! Thanks for the help here!!! Ill have more questions later!!
Smurf
Old Jul 6, 2007 | 03:31 PM
07FLHRCMarinePatriot's Avatar
NuJohn - after a few days please let me know your impressions (i.e. engine heat, performance, sound): You got the EXACT setup I want to put on my 2007 RKC.
Thanks[8D]
Old Jul 6, 2007 | 05:24 PM
iclick's Avatar
iclick
ORIGINAL: 07FLHRCMarinePatriot
Thanks[8D]
I think you'll like this setup, which is identical to mine. Jamie's map is excellent, and below is a dyno chart of the map he'll likely be installing in your PCIII. I've tweaked mine in the cruise and take-off range for mileage, but this hasn't altered overall performance. Heat is under control, too, even with my modified map.
[IMG]local://upfiles/4327/7E7C3D16A37A4761A0CE64CE387ED2AA.jpg[/IMG]
Old Jul 6, 2007 | 05:34 PM
Fishguy001's Avatar
Fishguy001
I got the same setup plus I added Vance and Hines Dresser Dual headpipes. Runs very well even though I haven't adjusted the throttle position yet. I do think the 1.75" Rush pipes are damn loud though and almost a tinny sound at times. I wonder if I have a defective baffle ? Bike runs cooler and better (although the boys got hot running for a couple hours in 90 degree temps with high humidity yesterday). But then I'm the founder of the toasted nuts club so the boys are allowed to get hot.
