POWER COMMANDERlll
Old Jun 30, 2007 | 08:05 AM
nujohn's Avatar
nujohn
Default POWER COMMANDERlll
IJust got my pclll and K+N air filter my rush 1.75 slip-onswill be here next week. Ihave been running 2' super flow slip-onsmuffler on my 03 RKC ( with lots of popping on decel was told would happen ) Now here my question ??, can I install my PClll and A/F on now and use with my mufflers and change out my slip-ons next week when new ones arrive with out hurting anything???
Jamie set the PClll for the 1.75 and k+n A/F
Old Jun 30, 2007 | 09:35 AM
nujohn's Avatar
nujohn
Default RE: POWER COMMANDERlll
I guess its one of the dumb question no one answer,s ? If its the typos I guess I sould check befor posting
Thanks anyway
Old Jun 30, 2007 | 11:30 AM
jeepster09's Avatar
jeepster09
Yes you can, it won't hurt anything.
Old Jun 30, 2007 | 05:34 PM
Taterdog's Avatar
Taterdog
Don't forget to set your 0% and 100% throttle positions when you install your PCIII. Seems most of us forgot the first time we did it! [:@]
Old Jun 30, 2007 | 09:34 PM
iclick's Avatar
iclick
ORIGINAL: nujohn
It won't hurt anything, but like Taterdog said be sure to set your 0% and 100% TP first thing after warming the bike up. When you install your slip-ons be sure they are on tight, as Jamie says that's the cause of the decel popping. It would be a good idea to use some anti-sieze compound on the joint when you install the mufflers. It will seal them better and make it easier to remove them in the future if necessary.
Old Jun 30, 2007 | 09:40 PM
Law Dawg's Avatar
Law Dawg
From: Rep of Maryland (currently serving in Afghanistan)
WON'T HURT ANYTHING
Old Jun 30, 2007 | 11:23 PM
nujohn's Avatar
nujohn
My thanks to all
Old Jul 1, 2007 | 12:08 AM
Fishguy001's Avatar
Fishguy001
You need to set the throttle position even with a fuel moto map ?
How do I do that ?
Did I screw my bike up by not doing it ?
Should I Evil knievel it into the local lake and be done with it ?
Old Jul 1, 2007 | 12:16 AM
hd2007's Avatar
hd2007
yes you have to set the throttle position ,open power commander tools , and then click set position , zero , then full , I do it while running .
ORIGINAL: Fishguy001
How do I do that ?
Old Jul 1, 2007 | 12:17 AM
Bryan1724's Avatar
Bryan1724
How do I do that ?
Yes this is something YOU must do.
Here's a link on how to do it. On the left hand side of the page scroll down to #10.http://www.powercommander.com/powerc...downloads.aspx
I didn't set mine when i put the PCIII on and almost had a meltdown.[] You would be able to tell pretty quick if it was running lean like mine was. When i did go to set it my throttle itwas at 6% open when it should have been reading 0% at idle.
