Starter Fire?!?!?
Old Sep 24, 2018 | 01:15 PM
tankthebiker's Avatar
tankthebiker
Unhappy Starter Fire?!?!?
Hello all,
I was riding my 06 Road King to work today and the battery light came on. I turned around and headed home. The light would come on as I came to a stop at lights but at speed it would stay on. Then I smelled it....the starter or something in that vicinity started smoking so I parked it and will have to get it tonight.....what in the world could cause a starter to catch fire? What else is near there that could burn up like that?
God Bless.
Old Sep 24, 2018 | 02:14 PM
hattitude's Avatar
hattitude
Um.... you walked away from a bike that was smoking...!?!?! You seem to have left out some details...
You had a battery light that stayed on, you smelled something and saw smoke near the starter, and then you parked it and "will get to it tonight"??? I sure hope it's still there for you to "get to" tonight.... I hope you pulled the battery ground before you left it.....
If you have a battery problem and smoke near the starter... it could be a short, which if not addressed could cause a fire....! Hopefully when you shut it down, it took power away from whatever leg/wire the short was in..... The starter, however, has some large cables that lead directly to the battery. If they short out, it could be like shorting directly to a battery terminal. A 12v short, straight to a battery terminal, can weld a wrench to metal, it's nothing to take lightly.....
In any case, first thing you need to do is pull the ground terminal off your battery!!!! It will remove the possibility of another (or continued) short. With smoke & a burning smell, you may not need a voltmeter to find the problem. I would do a visual of all wiring around the battery and the starter.. You are looking for chafing that wore through a wire cover and touched the frame/ground, or a connection that came loose enough to touch the frame/ground..... Based on your description, it should be easy to see. There may be a lot of black charring around a wire or portion of the frame, or at least some discoloration due to heat.. It's also possible something in the starter shorted out internally. Again, smell and signs of burning could lead you to the culprit. If you can't find anything on a visual, you need to get out the voltmeter and start checking wires.
I wouldn't reattach the ground wire until I was confident I found the source of the heat/fire....
Good luck with the repair....
Old Sep 24, 2018 | 02:25 PM
Roadie13's Avatar
Roadie13
I'll put my bet on loose battery cable and smoke was getting sucked out and looked like it was coming from starter.
Old Sep 25, 2018 | 07:14 AM
tankthebiker
I definitely removed the battery cables. I dropped it off at the dealer last night and it was indeed the starter that let the magic smoke out. I am working with them to find the cause of the issue. I am thinking something like a relay failed and caused the starter to engage and not something failing and over volting the system.
Old Sep 25, 2018 | 09:09 AM
hattitude's Avatar
hattitude
I would be interested to know what they ultimately find......
Please post up the results when they get it fixed..
Old Sep 25, 2018 | 11:58 AM
tankthebiker
Will do. They are ordering a starter now and it will be there in a week. As Tom Petty says, "The waiting is the hardest Part"
Old Oct 1, 2018 | 06:57 AM
tankthebiker
So update on the bike. It seems that the starter switch failed and locked to the "Start" position causing the starter to fight the motor or run continuously which is most likely the cause of the issue. We will see once it is all buttoned up.
Rkatxrider85
May 12, 2019 08:57 AM
teeboz
Sep 4, 2013 01:50 AM
jwhit101
General Topics/Tech Tips
Oct 17, 2011 06:43 AM
parichar
Oct 1, 2011 02:33 PM
84sugar
EVO
Mar 23, 2008 11:46 PM
