Sound about right to me . Mine runs around 35 on the road, sometimes higher to about 40 depending on temperature. It get to about 15 at idle. 2011 Ultra Limited.
Your idle oil pressure is determined by idle rpm, filter, oil pump and correct oil.
You have oil jets that cool bottom side of piston. They have reliefs in them that opening above 15 or so. That way, at a red light, oil in the short term is not overheated.
When you pull out, they open and cool and blowing air cools.
The high is the relief spring valve opening in the cam plate and bleeding off oil. The 35 or so is pleanty of pressure to get oil all over ever part of engine without pushing past seals or into primary.
Never above 33 psi, probably where relief is set. Once hot idle is around 12-15. Running down the road about 30-31 at ~2900 rpm and about 28 psi at 2500rpm.
My 2014 FLHTk is just like his, concering oil,pressure readings.
I try to take it easy when engine is cool and oil pressure is high. I wait till I am in the 30's before I push it past 3,000 RPM.
Lugging the motor is (at least in my opinion) a bad thing to do; hard on the machinery and probably does get enough oil flow onto the critical high pressure high temp. contact parts. There are also other reasons to not lug it.
It's also worth pointing out that our engines rely on a high flow-rate, not high pressure. 'Twas ever thus, with the big twins of all generations being made up of mostly ball and roller bearings!
