Oil Pressure ?
Old Sep 26, 2018 | 01:30 PM
Cossack84's Avatar
Cossack84
Originally Posted by BB59
Here is a good video explaining why oil pressures vary so much and the damage low oil pressure can cause.
https://www.youtube.com/watch?v=pFI2Kd6D2Q8
That was not the reason that motor failed, ~33 psi for the pressure relief is a proper setting. It takes a lot of oil flow for that valve to start bypassing at 30 psi, meaning plenty of oil to lubricate the motor. Also not a centrifugal oil bump, but a gear style pump with positive displacement. Again that is a wrong diagnosis of that failure.
Edit that guy has no clue how the hydraulic systems work. 20 psi on intake and 10 psi on the bypass does not mean that the bypass leaks 50% of the flow! That video is the reason you cant trust internet.
Bluehighways
2014-2024 Touring Models
20
Apr 6, 2017 07:34 AM
brettnbama
Jan 10, 2013 05:40 AM
FL-kruzen
Nov 13, 2012 04:50 PM
MichiganRider
Jan 9, 2012 12:44 PM
FL-kruzen
Oct 23, 2011 10:37 AM
