Rear Sprocket
Old Sep 26, 2018 | 11:27 PM
FrogHair's Avatar
FrogHair
6th Gear
Default Rear Sprocket
Has anybody changed out the rear sprocket for a 61 tooth and if so what drive belt did you use ? tia
Old Sep 27, 2018 | 10:38 AM
grbrown's Avatar
grbrown
Exclamation
Model and year of your bike please! AFAIK the 61T is an old size, which my International spec FLHS came with in 1990 and which won't fit more recent models (although it may if machined to match the hub). It takes a 1 1/2" wide belt.
Old Sep 27, 2018 | 11:20 AM
FrogHair's Avatar
FrogHair
6th Gear
Working on a '94 FLHR, rear sprocket came off a '93 FXSTC, it is a 1 1/2 inch belt on both ....
Old Sep 27, 2018 | 11:48 AM
grbrown's Avatar
grbrown
Wink
I did the reverse change to my bike, went to US spec from International! If you check a parts website you can find that size of sprocket, which is #40236-88A and the same one that came on my bike. The correct belt is #40023-86, 132T. You can check all this on that link.
Old Sep 27, 2018 | 04:15 PM
FrogHair's Avatar
FrogHair
6th Gear
Thank you , Thank you, just exactly what I needed ......
sbrmike
Apr 9, 2018 10:58 AM
98hotrodfatboy
19
Feb 26, 2018 05:51 AM
Son of PMS
EVO
Nov 11, 2014 11:39 AM
shovelhead FXEF
Shovelhead
Feb 1, 2013 03:26 PM
wpd910
Feb 27, 2012 05:17 AM
