Help Please
Old Sep 27, 2018 | 02:26 PM
Big Pete1's Avatar
Big Pete1
1st Gear
Default Help Please
Hi Everyone
I have a 2011 Road King, heavy breather and V&H pipes, everything else is stock.
My bike started running a little rough a month back after I got fuel. Just like a faint stutter every so often.
I reckon I could hear some pinging as well.
It carrys on when I am at cruise speed, around town, the problem goes away when under acceleration on the open road.
It gradually got worse over the last couple of weeks, carring on around town and at 55MPH
It starts out great but after it warms up (10 miles) it starts it's stuff.
I pulled the codes and it led to CKP sensor.
Replaced the CKP sensor but bike is still running rough although the code doesnt come up now.
What should I check next???
Thanks
Pete
Old Sep 27, 2018 | 02:59 PM
dyna rider's Avatar
dyna rider
Default Gas
Since it started at the gas station, I would drain the take and refill it with gas from a known good source.
Old Sep 27, 2018 | 03:09 PM
nobodyknowsme's Avatar
nobodyknowsme
Check spark plugs for abnormal color/fouling.
Old Sep 30, 2018 | 12:43 AM
Big Pete1's Avatar
Big Pete1
1st Gear
Found the problem.
It was a loose wire going to the rear fuel injector.
Old Sep 30, 2018 | 10:38 AM
MotoJockey's Avatar
MotoJockey
Thanks for checking back in with the fix. Glad you got it.
Old Sep 30, 2018 | 10:46 AM
PDB17UltraRG's Avatar
PDB17UltraRG
Same here glad you found it its always something small i was going to recommend you change your gas. Its a problem these day if you get a bad tank full.
Old Sep 30, 2018 | 11:09 AM
Almostinvincible119's Avatar
Almostinvincible119
I know you solved your problem, but You stated you’re running a HB and pipes. Do you have a tuner? It would help heat and running conditions tons.
Old Sep 30, 2018 | 05:05 PM
Big Pete1's Avatar
Big Pete1
1st Gear
Yes mate, I am running a tuner.
The previous owner set it up.
I have owned the bike for 12 months now and I love it.
Thanks for your input.
GomerPyle
Aug 10, 2017 07:16 AM
chaselee
Jun 18, 2017 10:23 AM
kingmoochr
Sep 23, 2015 10:53 PM
stan928
Jun 4, 2013 04:29 PM
tombeving
Jun 26, 2012 11:56 AM
