Gear oil
Old Oct 7, 2018 | 08:21 PM
klammer76's Avatar
klammer76
Used it in all my 5 speeds and use it in my SE 6 speed in my 2002. Never an issue.
Old Oct 7, 2018 | 08:29 PM
TriGeezer's Avatar
TriGeezer
Originally Posted by Cogswell
I used Bel-Ray last change in mine, seems to work well so far.
BTW...finding neutral has nothing to do with transmission lube. Primary lube & clutch adjustment YES.
Old Oct 8, 2018 | 12:00 AM
MotoJockey's Avatar
MotoJockey
Originally Posted by Simpleman71
Anyone running Mobil 75W 90 gear oil in their 2018 touring models?
Not wanting to be "That Guy", but personally, I wouldn't run anything in an M8 gear box that I didn't want all over my clutch plates until I verified FOR SURE that it didn't have a case of the "Dreaded Transfer!" I'd stick with Formula+ till you know. Or maybe you already know it doesn't and I should shut up, lol!
Old Oct 13, 2018 | 01:24 PM
houstonhdguy's Avatar
houstonhdguy
I just had my oil changed and went back to Bel-Ray for the trans. Bike seems to shift noticeably very smoothly.
Im sure many other good products are out there.
Old Oct 13, 2018 | 01:29 PM
TriGeezer's Avatar
TriGeezer
Originally Posted by blue bronco
Just did 1k service and I brought them (dealer) the red line power pack. You will notice how easy it is to find neutral after the change. you will 1.3 quarts for m-8 107,
need to buy extra quart for trans
Finding neutral is about the primary & clutch...not the transmission.
Old Oct 13, 2018 | 03:57 PM
Pantera99's Avatar
Pantera99
I put bel-ray big twin transmission oil in the tranny at the same time I change my primary to Rotella T4 15w-40. The PO ran all Syn 3. Much easier to find neutral now so what you're saying is the Rotella T4 made the difference?
Old Oct 13, 2018 | 04:20 PM
golfblues's Avatar
golfblues
Different oils work better in different bikes. I went to Screamin Eagle clutch plates in my 09 Heritage and at the same time switched to spectro heavy primary fluid from Rotella T. I have Spectro 6 speed in my tranny and love it. I could not find neutral at all with Spectro primary oil even after many clutch adjustments. I then changed to Harley-Davidson primary formula plus and it was 80% better but still hung up at times. Before I made these changes I had Rotella T and never had a problem so I picked up Rotella T4 15-40 the other day and put that in and now finding neutral is as easy as ever. Spectro primary works fine in my 06 softail with Spectro 75-90 gear in the tranny. Sometimes you have to experiment.
And I believe the T4 made the difference for your bike. T4 replaced the older T version.
Falcon195
Jul 8, 2013 10:43 PM
Sgt_Jim
Oil Archive (no new posts)
Dec 29, 2011 09:03 AM
Woodchuck
Jun 18, 2011 12:37 AM
mjaw
Feb 8, 2008 11:18 AM
liv2hunt
Apr 9, 2007 09:23 AM
