Strange noise when clutch is engaged
Old Oct 5, 2018 | 08:06 AM
johnshaffer1963's Avatar
johnshaffer1963
1st Gear
Default Strange noise when clutch is engaged
2009 flhtcu, My bike started to make a noise on the way home from work when I pull the clutch. It sounds like the starter is trying to engage. Any clues?
Old Oct 5, 2018 | 09:57 AM
mmesa005's Avatar
mmesa005
I would start by checking the following:
  • Clutch adjustment
  • Primary Chain Adjustment
    • Inspect tensioner shoe
  • Primary Oil Level
  • Transmission Oil Level
A Service Manual will be very helpful as you go through your inspections and adjustments.
Old Oct 7, 2018 | 09:35 AM
F150HD's Avatar
F150HD
does it do this when idling in a parking lot? (when clutch pulled in). post a video
Old Oct 7, 2018 | 10:19 AM
johnshaffer1963
1st Gear
I was able to isolate the problem. Once I started the bike I unplugged the starter solenoid. Rode it for 20 miles and no problems. I believe the problem to be in the switches or harness.
Old Oct 7, 2018 | 12:37 PM
Guntoter's Avatar
Guntoter
A 2009 police bike, from my former department, did the same thing one time years ago. If I remember right, I sprayed some silicone in the starter switch and button locations on the switch housing, worked the switch and button a number of times (shut off of course) and it never came back.
Old Oct 8, 2018 | 07:44 AM
btsom's Avatar
btsom
Definitely NOT intuitive in that the clutch lever is on the left and all of the start and run switches are on the right. Any evidence of chafed wiring around the steering head?
RKCButcher
Mar 9, 2018 06:11 PM
drbologna
Nov 6, 2017 08:37 AM
largeswine
EVO
Oct 1, 2017 08:26 PM
richardgarcia04
Apr 4, 2017 11:15 AM
Ultra103
Feb 2, 2014 10:50 AM
