Oil use
thank you I just wanted some opinions thats all I did the work last winter and only have had time to put 6000 kms on all year due to having a baby
*Using a little oil is not a bad thing.
The more modded an engine is, - the loser they are set up.
It is all compromise
*In the AirCraft world, people brag about their particular power plant being so stingy with the oil.
Those of us that have been around the block know if it is NOT using
some oil, about halfway through its life it will be using a LOT!
Again air coolers just can't contain themselves....LOL
im just wondering if its rings or blow by because I can smell it out of the air cleaner at stop lights and like I said it has zero smoke out of the exhaust Ive had it on a dyno a couple times and saw nothing and everyone who is behind me say they see nothing at any throttle position
i did put new umbrella valves in from HD but never opened the drain holes up and I did go to a larger open air intake as well then what I did run in the past
What is the spec?
Pardon, it's been since the 1980's since I've done a topend. I might be all wet with this. Seems like .001" per inch of piston diameter was what we used when building (and assembling!) engines.
What is the spec?
thats what they came from HD I ordered the 103 piston kit from them
What is the spec?
the pistons were fit to each jug to 1 thou 2 tenths all rings were put in the proper way and turned as per manual
Okay Im not saying your are wrong about an air cooled harley. I just know I have a air cooled V twin on my lawn mower. I run the mower at WOT for four hours at a time. It doesn't use a drop of oil for the whole season. Just say n.
im just wondering if it’s rings or blow by because I can smell it out of the air cleaner at stop lights and like I said it has zero smoke out of the exhaust I’ve had it on a dyno a couple times and saw nothing and everyone who is behind me say they see nothing at any throttle position
Pretty simple to fall off a log.
still has the oem camplate and pump in it and I dont experience much oil use running in the city or back roads seems more when I run 70 mph for extended time
