Day 2 New Bike and I Scratched it Nicely
Old Oct 13, 2018 | 10:24 PM
groupw's Avatar
groupw
Originally Posted by run1fsr
...now that's out of the way and you can begin enjoying the bike.
..... you can always just cover'm up, specially w/winter upon us.
PS: don't feel bad, i dropped the above machine on my 2nd day .....Got it outta the way.
Old Oct 14, 2018 | 01:53 AM
woodreaux's Avatar
woodreaux
It’s always disappointing when things like that happen.
Things like this are going to happen it’s just a matter of when.
Go ride it- other road debris and rock hits will overshadow this incident.
Old Oct 14, 2018 | 09:51 AM
Oko's Avatar
Oko
sgnden - That sucks. Was there alcohol involved? Just kiddin'. I got rid of the HD pins and went with the knobby screw type. They take longer, but I went through 4-of those HD ones. I guess I'm too stupid to use them correctly.
Also, go grab a beer and vacuum the garage floor. And put down some rubber mats. And grab some more beer.
Old Oct 14, 2018 | 10:03 AM
skratch's Avatar
skratch
in 2017, hd went away from the dzus pins and implemented a screw type fastener. if you go with a 20% off dealer, you can get them for a good bit cheaper. hell, at this point, even at full pop, less than what you'll spend to fix what you've got now. sure, you can buy the aftermarket kit cheaper, but the hd kit has some benefit. the u nut that attaches to the mount points are more substantial, and the 'bolts' have these washers that are affixed to them that have little **** on them that when you tighten them down, act as lock washers.
simple install. well worth the cost of admission.
Old Oct 14, 2018 | 11:00 AM
sgnden's Avatar
sgnden
Thanks, Skratch. I'm all over that.
On my RK, I installed the anti theft screw style as one of my first mods back then. I won't do the anti-theft screws again as it's a pain to find the tool every time, but great idea to convert!
Old Oct 14, 2018 | 11:34 AM
FNGonaRK's Avatar
FNGonaRK
Run your fingernail over the scratches and see if it hangs in any of them. If not, you can most likely polish them out. I would start with Meguiar’s 105, then Meguiar’s 205. If the fingernail hangs, repaint, or replace.
Old Oct 14, 2018 | 12:01 PM
Bingee's Avatar
Bingee
I'd forget trying to repair it. You can find a new one or near new one on eBay for less $$ than you can paint one. Get one. Switch the hardware and you'll be back to new. Just look for OEM lids '14-'18.
Old Oct 14, 2018 | 12:06 PM
Spartanden's Avatar
Spartanden
it's been mentioned... but I swapped out the dzus pins for threaded ***** with a clip nut in place of the retainer on the frame. They do loosen up, but i'm in the bags enough, I habitually give them a crank! I also got some clear plastic bumpers and put on each corner on the bottom. That way I can set the bag on the floor and not have to worry about being on the paint on the bottom of the bag. Then lastly I bought a 6-7" wide roll of clear 3m plastic film that I applied to the lid. That will help keep the scuffs and boot heel marks off. Otherwise, just be careful!!!! Kidding of course, but you have some tips. Follow through what you feel comfortable with. Good Luck!
Old Oct 14, 2018 | 12:09 PM
Sixgunjr's Avatar
Sixgunjr
It’s good luck! The 1st and last scratch you’ll ever get. Lol
pretty much every new car or bike I ever got get a freaking scratch in the 1st week.
Old Oct 14, 2018 | 12:15 PM
sgnden's Avatar
sgnden
Yeah, time is my issue for sure. I looked on Ebay and searched in Googletron but didn't see any painted ready-to-install lids. Will check back from time to time, I guess.
Thanks!
