Umbrella valves
Old Oct 19, 2018 | 04:12 PM
2014sportsteriron883's Avatar
Default Umbrella valves
is there a better replacement for the stock ones? I’m thinking this may be apart of my oil usage issue as the leak down test is good and I can smell oil at stop lights
winter is coming and a new s&s oil pump and camplate is going in so I was going to drill out the drain holes and hopefully put new umbrella valves in again
Old Oct 19, 2018 | 07:13 PM
CSMHOG's Avatar
CSMHOG
Valve guide seals? Do you have white smoke coming from exhaust?
Old Oct 19, 2018 | 07:14 PM
CSMHOG's Avatar
CSMHOG
Kind of hard to screw up umbrella valves. Harley’s are fine
Old Oct 19, 2018 | 07:25 PM
zero smoke at all just a oil smell from the air cleaner and oil use
Old Oct 19, 2018 | 07:33 PM
CSMHOG's Avatar
CSMHOG
How much oil are you using between oil changes?
Old Oct 19, 2018 | 07:38 PM
1 quart every 3100 kms
Old Oct 19, 2018 | 07:52 PM
CSMHOG's Avatar
CSMHOG
What bike are you having this issue with?
Old Oct 19, 2018 | 07:58 PM
08 sg that I just bored to a 103 last winter se 204 cams heads shaved down 10 thou build only has 5600 kms on it ccp is 205 each cylinder with acr disconnected has zero smoke pulled good numbered 98 hp 118 tq runs strong just bugging me about the oil use
heads were rebuilt with cometic seals
i had a post about this earlier but looking for different routes to take to eliminate the issue
Old Oct 19, 2018 | 08:10 PM
CSMHOG's Avatar
CSMHOG
sounds like a great build. Depending on your air filter, I’d think you’d notice that much oil getting past your umbrella valves have you checked your primary fluid level in case your crank oil seal is going?
Old Oct 19, 2018 | 08:15 PM
im running a larger k&n open filter and it is fairly soaked with oil
primary fluid is good I just checked that
