Front wheel alignment question
Old Oct 27, 2018 | 08:13 AM
  #31
barneyboy's Avatar
barneyboy
Originally Posted by Bumpandrun
Hey you ole hippie bastard!! Lol. Bike has never been down ...ever....can guarantee that. Give you a bit of history on your Bike. Brake light switch was done not 1 month before you bought it. ( also HD did it n 2013) Guess the Indy couldnt see that it was brandnew. Front and rear aligned here ..by myself. The rear cams on the rear axle are different to get it perfect on your bike.....One has a tiny bit removed to square rear to front. ( so if he was sloppy doing rear tire it may be off a tiny bit) When the front forks were serviced I also did the neck bearings and checked tripe trees...The front was also aligned to the rear. Guessing maybe Indy was sloppy on your bar install. The rear belt and sprocket were in excellent condition 5-7 k before you bought it. ( that's puzzling as That bike was going to be my last so it got everything it needed) I have a funny feeling you need a new Indy....something doesn't smell rite. I would tell you this winter... I would check cam tensioners again if your over 45k. It was in my list if to do next....No reason to,BS you already bought it...lol. Was coming up this weekend but weather looks horrible.
Wouldn't this misalign the rear axle to the rear fork pivot shaft, which in turn would misalign the rear spocket to the transmission spocket, leading to premature belt/sprocket wear?
TexasUltra
Apr 23, 2024 12:04 PM
dbeach2014
Sep 5, 2015 12:42 PM
Eunoterpsia
Aug 17, 2015 02:22 PM
arrowslinger1980
Jul 3, 2012 02:31 PM
Yachtman
Nov 20, 2009 02:14 PM
