My 2012 UC was also a US bike that I purchased here in Ontario. The Indy I purchased from sells truck loads of US bikes every year. To satisfy our regulations, they just stick a "km per hour" sticker on the outer face of the speedo. The sticker is calibrated (and I use that term loosely) so the when the bike is running 62 mph on the original speedo, the needle is showing 100 kph on the sticker. Odometer still reads miles of course.
This was fine for a while but I wanted a KM speedo. Researched it a fair bit and as a previous poster has said, you can order a new KM (or KM/MILE combo) speedo from HD. They require your current mileage...when you receive your new speedo, it will not be at zero, it will have your current mileage as a starting point. And yes...the price is pretty steep!! I went the route of used gauges instead. I found a full set of Street Glide gauges (I like the silver as opposed to black) from a Canadian bike & swapped them out. I got my complete set with only 642 km's on the speedo for only $100. Lots of guys swapping out the original gauges for digital versions. Contrary to what some may say, the ECU does NOT store the mileage and transfer it over to the replacement speedo. Installed and plugged in, and all works perfectly...easy peasy. Odometer reads the accumulated km's from the original bike (642) and started counting up from there. I recorded my mileage (converted to km's) when I removed the original speedo...recorded the km's on the used replacement speedo. Because the replacement speedo had such low km's on it, I need to add 9,526 km to what is showing on my odometer for total km's on my bike. I will disclose this if & when I trade or sell it.
Canada doesn't require the "square" brake light. They DO require a dedicated brake light in that it can't be the same used for signals. I taped/velcroed an old sportster brake light on, changed my red lens to ambers that I had and went to Canadian tire. They passed it without even turning it on to see if they work.....lol. You can also just get those 70's style km speedo stickers for the speedo and then take them off after inspection. My last 2 bikes have been US imports. The crappy dollar ended that!
I just took off the license plate and screwed the original light into that . License plate is not part of the riv inspection. Apparently the sticker no longer works, Canadian Tire is required to take a picture and send it in. The are also required to take picture of the serial numbers off the exhaust and submit them to see if they pass requirements, so I'm told.
Correct. But to be clear re a previous post, Canadian bikes are still made (and shipped) with the big square tail light. Many pics used are of US bikes but this below from HD Canada website of a 2019 SGS. If you go to "Explore Paint in 360ş"and rotate the bike, you'll see the big square tail light...
