air ride problem
Old Nov 16, 2018 | 04:06 PM
hotrod351's Avatar
hotrod351
Default air ride problem
i have a slow leak in my air ride, havent found it yet, the leak. biggest problem is trying to air them up, the valve stem is located in a bracket behind the left saddle bag. problem is that the bracket that holds the valve stem is so thick that i cant air the air shocks up unless i remove the valve stem from the bracket, then i air hose will fill them. is there a longer valve stem setup to i can fill them without removing it from the bracket. also i going to replace the air line but dont know what size it is, any help will be appreciated.
Old Nov 16, 2018 | 09:03 PM
memphisharley's Avatar
memphisharley
air line size should be 1/8
Old Nov 17, 2018 | 06:10 AM
1HD1C's Avatar
1HD1C
you should be able to get a hand pump on it without a problem with the saddlebag lid open
is the valve not adjusted correctly?? general a nut on the back and a nut on the front and you adjust them
so more of the valve sticks through the bracket and then tighten
as for the leak, get a small spray bottle from the dollar store some dish soap and a little water and start spraying fittings
Old Nov 17, 2018 | 01:45 PM
hotrod351's Avatar
hotrod351
1/8", thanks. the valve stem doesnt have but one nut, the one that tightens it, no nut on back side, still it doesnt come though enough to get a air line on it.
Old Nov 17, 2018 | 01:56 PM
Hammz's Avatar
Hammz
If this is the oem air shocks, you should never be using an air hose from an air compressor. You need to purchase a pump specifically made to adjust the air pressure. An air line has too much pressure & too much volume to properly set the air ride correctly. It'll blow out the lines/fittings & cause bigger leaks.
Old Nov 17, 2018 | 02:02 PM
Wisenheimer16's Avatar
Wisenheimer16
Those air shocks are junk. I had a shock leaking oil a few months after purchase. (16 Ultra) The support they give with a passenger sucks as well. Most of us go aftermarket shortly after purchase. It felt great ripping out the air lines after putting some Progressives on.
Old Nov 17, 2018 | 04:26 PM
grbrown's Avatar
grbrown
Wink
It sounds as if your bike does not have the original air valve. I have to agree that Wisenheimer16 has put his finger on it - those shocks are not worth spending any effort on. The season of good will is almost on us and you could treat your bike - and you - to a set of nice new 'normal' shocks, which don't need air. However if you are determined to sort yours out and can post a photo of the valve we can probably help. You can check this parts website, which shows what your stock setup is.
Old Nov 17, 2018 | 05:24 PM
Oko's Avatar
Oko
Get rid of those HD air shocks. I went with Pro Action.
Old Nov 17, 2018 | 07:39 PM
RETSSG's Avatar
RETSSG
5th Gear
If you still haven't fixed it yet you may try a valve stem extension from the parts store used on dual wheels . But really it would be better to just rebuild or have a proper repair done for your safety
hotrod351's Avatar
hotrod351
this is the valve, looks
a standard aftermarket valve to me.
