Roadking draining battery
Old Dec 30, 2018 | 10:58 PM
Morgan523's Avatar
Morgan523
1st Gear
Good info. Thanks to all.
Old Dec 30, 2018 | 11:02 PM
dickey's Avatar
dickey
Keep it on the battery tender anytime you are not riding it.
Old Dec 31, 2018 | 04:31 AM
gja's Avatar
gja
Have it load tested. I had the same problem recently. Ended up being a bad cell in the battery. It would take a charge and start the bike right after disconnecting the battery tender. Let it sit overnight without tender and it would be dead.
Old Dec 31, 2018 | 11:12 AM
95th 1200's Avatar
95th 1200
If you won't be riding it for more than a few days, keep it plugged in. As for now, take the battery in somewhere and have it load tested. If the battery is more than 4-5 years old it's probably starting to go south, a load test will give the current state of health. IIRC OE bagger batteries are rated at 410cca. You may have 12.65v, however only be down to 200cca. If the battery is toast, get a replacement designed for a motorcycle. I've seen it numerous times where someone comes in with a two year old dead battery, only to find its a lawn tractor or golf cart battery (multiple application design). Motorcycles, especially Harleys, shake the living hell out of the battery and are physically tough on them. Also stick with AGM as opposed to the cheaper lead-acid type.
Old Dec 31, 2018 | 11:46 AM
grbrown's Avatar
grbrown
Wink
In addition to all the good advice above, consider a few simple house-keeping tasks, such as cleaning and tightening both ends of both main battery cables. Use a little dialectric grease on them before reassembly. A dry, corroded or slack fastener on any one of them can increase resistance and hence reduce battery performance when starting. Do the same with other major electrical connectors/grounds associated with the starting circuit.
Old Dec 31, 2018 | 11:55 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Replace the battery. Or put a DC meter set on amps between positive cable and battery. With key off, it should be less the 150 miliamps for speedometer, ecm and alarm draw.
If it's more, you are going to half to pull fuses to find problem.
Two weeks on a sulfated worn out battery is good however.
Usually if it last that long, it's the battery
Old Dec 31, 2018 | 01:02 PM
im's Avatar
im
Originally Posted by Morgan523
I have a 2004 Roadking that will drain the battery if it sits very long without starting it. Any ideas what to start looking at? The battery tests good and takes a charge.
In an effort to get assistance folks sometimes throw out a question but forget to add information.
After reading it a few times it would seem that you have a bike that will not start after a few weeks of no use.
Would a few weeks be 2 weeks, 8 weeks, 16 weeks?
Reason: A regular lead acid/agm (wet battery) will have a loss of charge over time. A small demand like an alarm could cause a no start situation after several weeks (6 weeks).
You report no security system but then we learn that you have keyless start...guessing you have a key fob..is it factory?
Would it be possible that you do have a security system since it requires key fob proximity to start.
A keyless system could cause bike to not go to sleep and it would maintain a slight demand on system.
OR is it possible that your bike does have a siren and the rechargeable battery for siren has become compromised and is causing a parasitic drain situation.
You report that battery was tested and takes a charge (takes a charge from what? from bike or wall charger?)...How old is the battery? How was it tested? was that a load test? a meter at battery? what test was performed?
From a distance and based on information available it would seem like there might be a parasitic drain but you really need to confirm battery condition, motorcycle charging condition and then reason for drain.
Here is a link for a parasitic drain test.
Old Dec 31, 2018 | 02:15 PM
bobg03's Avatar
bobg03
I leave my bikes plugged in year round, had a road king with an older style tender that had a slide switch on back of it, left was 1A, Center was off (power light stays green in this position) and right side was 2A. The charger inadvertently got switched to off position when my wife moved it to get into roll chest it was sitting on. She always checks for green light when I am away for work. It was green but because charger was off the electronics wiped out battery. Lesson learned battery was 5 years old, I simply replaced it and got a battery tender brand that has no switches.
Old Dec 31, 2018 | 09:16 PM
skratch's Avatar
skratch
the op's bike is a 2004. even if it did have a security system installed, it would not be the proximity fob type as that did not start until 2007.
Old Jan 1, 2019 | 12:51 AM
im's Avatar
im
Good to know about year of availability for proximity sensor as i did not know that information.
Original Poster in post #5 states they have keyless start.
What is keyless start ? aftermarket? remote control?
Alarms, sirens, security stuff is sometimes the cause of a battery drain.
The rechargeable battery on a siren had me guessing on a car once.
Unfortunately, confirmation can not be made until a parasitic drain test is performed.
Hopefully the poster will return.
Esiegel91
Sep 27, 2016 08:46 PM
VTGlideRider
Dec 24, 2013 08:36 AM
veniculum
Aug 15, 2012 03:24 PM
OneBlackFly
20
Jan 23, 2011 09:31 AM
snuffer
Dec 3, 2007 10:26 AM
